Old 12-29-2006, 07:13 PM   #1876
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally Posted by uniquexme
ok thanks, now i know. but would the new 11.9 bearing difficult to find?
Our local hobby shop has these bearings in stock. I have already made my order for spares
doki_doki is offline   Reply With Quote
Old 01-14-2007, 01:22 AM   #1877
Trader Rating: 12 (93%+)
Default novarossi rex pr350 m-rossi?
hello
does anyone have any information on the engine above?
it has m-rossi engraved on the head and looks heavily modified inside.
crank is ported and has lead weights in it as well.
i wouldnt mind a part number for new piston/sleeve/rod that would be great
thank you
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-16-2007, 09:15 AM   #1878
nitro_moe's Avatar
Hi guys,,
Can anyone please give me the exact specs of the Plus 12 3CT and the Plus 12 5CT for comparison??
If not willing to type it out,, please paste a link..
Thanks in advance..
nitro_moe is offline   Reply With Quote
Old 01-16-2007, 10:03 AM   #1879
team novarossi's Avatar
Send a message via MSN to team novarossi
Originally Posted by nitro_moe
Hi guys,,
Thanks in advance..
only 2 more transfer ports then the 12-3CT.
It's not on the NOVAROSSI website because it's not race legal. (ifmar/femca/EFRA etc.)
team novarossi is offline   Reply With Quote
Old 01-16-2007, 10:59 AM   #1880
afm
afm's Avatar
Hi guys,,
Thanks in advance..
http://www.novarossi.it/eng/motori/plus123t3ct.htm
But these engines are now replaced with latest Plus 12 3 SCT, which changes crank to 11.9mm OD...they do not show on the web page yet
The 5SCT doesn't appear either, bu t as said before it has 5 ports instead of 3, but are not legal for sanctioned races, unless in an open class.
AFM
afm is offline   Reply With Quote
Old 01-17-2007, 04:47 PM   #1881
nitro_moe's Avatar
Thanks for your replies fellas..
I meant to ask about specs like rpm, hp, and bore/stroke. Anyways I found what I was looking for..
Thanks anyways..
Old 01-17-2007, 10:15 PM   #1882
ziggy12345's Avatar
The HP quoted is way off the mark. The highest HP recorded for any .12 engine is 1.15 for the CRF wasp. I have no idea where they get a figure like 1.68HP.
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-18-2007, 12:12 AM   #1883
why you think it's way off??
on the other hand you can think that the CRF underpowered.
NOVAROSSI power quotes come from benchruns with the best combination of header&pipe.
and we all know that makes a world of difference.
If somebody builds a engine bench to measure power with any factory support it will finacially impossible to test all the engines with their best set up combinations.
Old 01-18-2007, 01:35 AM   #1884
nitro_moe's Avatar
Although I am not that experienced and not qualified to answer, but I don't think a highly reputable brand such as Novarossi is going to publish a figure regarding their product which is incorrect.. Please excuse my humble opinion ..
Like Team Novarossi said, I'm positive that their engines have undertaken many test to prove their potential hp output. Besides, I really don't think the CRF has that much power to even come close to the Novas..
Old 01-18-2007, 07:58 AM   #1885
ziggy12345's Avatar
OSTZP Quoted Power Output = 1.35HP Actual measured =0.78
NSR12S3 Quod Power Output 1.52HP Actual measured = 0.85
Sirio EVOIII Quoted = 1.62 Actual measured = 0.9
These are figures from ACTUAL Dyno runs
The Murnan moded Sirio EVO III STI got 1.05HP
http://www.nitrodynesystems.com
Cheers
Sponsored by:
Norfolk and Chance
Old 01-18-2007, 10:34 PM   #1886
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
i wonder how palmaris PR12, OS Speed, 12-3CT Tuned got how much HP when dynoed.
uniquexme is offline   Reply With Quote
Old 01-19-2007, 12:31 AM   #1887
Originally Posted by Nitrodyne website
We will include the ex system used for testing with each engine for comparison, however your results might vary unless you use the same ex system as we did during testing.
here's youre answer why theres a difference in power output.
The difference in power output is ...as i see it: they don't have the latest&powerful exhaust systems.
NOVAROSSI/Sirio/OS/etc. has.
If you run a .21 (for instance a 35+) with a 2006 you get a resonable speed&power.
the 2006 is released somewhere around 2002 or so.
When you mound a 2052 pipe you get far more power from youre engine.
I don't have hard HP results...only laptime
If you get a lower laptime with a different pipe you have more power!
Old 01-19-2007, 04:26 AM   #1888
afm
afm's Avatar
Palmaris PR 12 BM 1.00 Hp / 31.33 oz/in torque
OS Speed TZ 1.03 Hp / 31.48 oz/in torque
You can see the graphs at http://www.nitrodynesystems.com/
AFM
Old 01-19-2007, 04:32 AM   #1889
afm
afm's Avatar
This is the real reason why manufacturers claimed Hp don't match real dyno tests...the most reliable source for real Hp comes from Nytrodyne Systems tests, because all engines are tested in equal enviroment conditions and using SAE correction factors, which gives us a real comparison table.
AFM
X-Dyno Horsepower vs. Claimed Horsepower
You may have noticed that X-Dyno power data doesn’t always match up with manufacturers’ claimed horsepower and torque figures. We attribute this discrepancy to the fact that many manufacturers publish theoretical horsepower and torque figures based on rough estimates rather than actual dyno data, or that a manufacturer’s data collection protocol doesn’t match our own. The X-Dyno calculates horsepower using known mathematical formulas and precise physical data measurement.Although the X-Dyno’s power numbers may not equal the numbers you’re accustomed to seeing, the figures we provide are accurate from engine to engine, and are directly comparable with power data from test to test.
Old 01-19-2007, 07:33 AM   #1890
Grinder's Avatar
Cheers
The Murnan Modified Sirio Evo 3 was not an STI. It was an old Evo 3. It hit 1.10 HP on the dyno with 31.60 oztq. The Murnan Modified Novarossi LS3 2007 updated edition just hit 1.15 HP with 33.41 oz. tq. With a very linear powerband. The Murnan Modified +12-3SCT just hit on 1.07 HP with 31.19 oztq. Not as much power as the short stroke. Stay tuned we are still playing with different pipe combinations. These may not be the final #'s. Just a sneak peak.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
