Old 12-19-2006, 01:40 AM   #1861
Bundy_Bear's Avatar
Originally Posted by ziggy12345
No. Its shimmed for 30% around. You need to reduce the head shims to give you 0.3mm head clearance.
For running in preheat the engine to 160 deg f and make sure you keep the temp up for the first 2 tanks on idle.
I wouldnt reccommend the WOT method (if you dont know what it is dont bother) This stresses the engine too much
Preheating... is that with a heatgun?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 12-19-2006, 01:44 AM   #1862
ziggy12345's Avatar
Yes or a Hairdrier
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 12-20-2006, 11:27 AM   #1863
Luti's Avatar
Default WOT method ??
What is it WOT method ??
Serpent 720 ´07 - Futaba - Mazda 6 - Byron 30%
Luti is offline   Reply With Quote
Old 12-20-2006, 11:42 PM   #1864
jaykay's Avatar
Don´t use a heatgun. There too hot. Use a hairdrier!!
jaykay is offline   Reply With Quote
Old 12-20-2006, 11:48 PM   #1865
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
heat guns are ok if you know what your doing you just dont hold it so close to the head and make sure its on the lowest seting
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 12-21-2006, 05:51 AM   #1866
afm
afm's Avatar
WOT BREAK-IN
Dave Gierke’s article in the January 2002 issue of “RC Nitro” magazine! "
Idling an engine and letting it run slow, 1/4, 1/2 throttle is incorrect. You want Wide Open Throttle after it warms up. YES Wide Open Throttle, even when it is brand new. This is in order to bring the engine up to temp. and fit the sleeve to what it was designed to run at. Anything less, and you are just leading your engine to an early death.
Yes, running at WOT slightly rich, but not 4 stroking rich is the proper way to do it. Here is some further explanation of ” the way”, and why it is the proper way.
As for break-in, there is a whole lot of misunderstanding about this basic engine operation.
Although we use the term “break-in”, by its wording alone it is misleading, because people wrongly assume it means to slowly and gradually bring an engine to tune by idling tanks of fuel, but you will see why this is incorrect and unnecessarily wastes fuel too!
It will take some time to convince yourself to bring a new engine to WOT, but when you start to understand it and why it is correct, you will realize just how many people are completely breaking the engine totally incorrectly.
It’s important to learn the theory about how these engines run ( 2 stroke ABC, ABN, AAC), and how to break them in, especially because I see WAY TOO MANY people using the wrong procedure of idling many tanks of fuel through the engine. That is unnecessary and damaging.
These engines use a sleeve around the piston to make the seal (piston doesn't have a ring) and it operates properly only with sufficient heat so that the sleeve can expand to its designed operating size and fit. All engines will be tight, especially when new, so on the initial runs, you want to have it get up to temp, so it can run how it is was designed to. By idling tanks and tanks through, overly rich and cool, the sleeve just wears MORE against the piston because it is not hot enough to expand to its operating size. And by doing that you are prematurely wearing out and ruining your engine. The piston/sleeve is designed to operate at running temps. Not doing this by running cool and rich on the bench leads to premature wear. By idling away tanks of fuel I GUARANTEE you are doing more harm than good. As long as the engine is warmed up first, you don’t have to drag out bringing it up to temp when it is brand new. It wont hurt or damage the working parts. These engines are very simple 2 stroke machines. They do not have extensive moving parts such as valves, cams, lifters, springs, etc. (like 4 strokers) so all this extra gentle, rich, cool operation is completely unnecessary (and worse it’s harmful). HOWEVER, the sleeve around the piston can be a delicate thing to maintain, and it is not forgiving of improper treatment, and improper treatment of a piston and sleeve is running it at a temp it is not designed for. (either too cold or too hot, both are just as detrimental) Most often this is done by running it too rich which makes it too cold because the rich mixture doesn't generate enough combustion heat for proper sleeve expansion. Just as damaging can be an excessively lean run. If it is run overly lean for any length of time it will destroy the sleeve. (that is why fuels with castor oil as part of the lube mix are very good because they tolerate the too high heat of a very lean run and will help to save the sleeve if it is not run too lean for too long (but avoiding a lean run is essential when you know enough about engine tuning to avoid it).
Running a 2 stroke engine slow and rich makes it '4 stroke' which means it fires every other revolution, and that generates even less heat. It causes damage and wastes fuel as well. Most important is to 'heat cycle' the engine at least 10 times to relieve the parts of manufacturing stresses. HEAT CYCLING REALLY IS WHAT BREAK IN IS ALL ABOUT. (I even think break-in should be called “Initial Heat Cycling” instead so that people understand what and why they are doing it.)
Run the engine in a bench for 2 - 3 minutes at full throttle (yes, WOT, don’t baby it), after briefly warming up of course, and then shut down and repeat after the engine has fully cooled. Let it cool down completely. Heat cycling is the name of the game. You want it to come up to temp for a brief time, and cool down and repeat. After shutting down, adjust the flywheel so that the piston is at BDC (bottom dead center) so that it does not get stuck in the contracting/cooling sleeve, as can often happen. (If the piston should accidentally get stuck in the sleeve, preheat the cylinder to free the piston from the sleeve.). Follow this procedure for at least 3 tanks, then put the engine on the car and do another 3 tanks at the track to finish Break-in, leaning the engine a bit after every run
During these initial runs YOU WANT the temps to be at least 90° C but not above 109° C.
After break-in, running temps above 109°C is fine. In fact new generation nitro engines perform best when run at 120°C – 130°C. Below those temps they are less efficient and less powerful.
However, going by the mixture is more important than trying to measure temp with heat guns, etc. which you may wind up doing inconsistently. The mixture setting on the High Speed Needle is critical in the first runs. It should be a rich and not lean setting. However it should not be so rich that it 4 strokes.
Also, to start a brand new engine it is very worthwhile to preheat the engine with a heat gun or hair dryer if it has a very tight piston/sleeve fit and you are having trouble turning it over to start it up. This will expand the sleeve some, and when you turn it over the piston will not excessively rub, or even get stuck in the sleeve (as sometimes can happen). Preheating really works well. You do want to run it on the rich side, but you want it to come up to temp also, just not more than 2-3 minutes in beginning runs, in order to keep temps around 109°C. Listen carefully to the exhaust noise or ‘note’, as you do not want it to be ‘4 stroking’. If it is, it needs to be leaned slowly until it runs 2 stroke. You can tell it is 4 stroking if it is very “boggy” and “hesitant” in acceleration and running. If it is making that “burbling” sound then it is 4 stroking which means it is running too rich and therefore too cold.
Everyone thinks they have to run it super cool and check to be sure temps are low. That's not what it is about. The reverse is true! Cool operation is damaging operation. Little, if any, break-in will occur unless it is heat cycled properly.
The manufactures can’t make a piston/sleeve turn over smoothly at room temp, because when the engine runs the sleeve will expand and there will be no seal at operating temp. See how that makes sense?!
So preheat it if necessary and don't run it cool, and heat cycle it, and you'll be good to go! After you have done this several times then you can gradually lean out the HSN to get best performance, but it should then be richened up just rich of peak to ensure it lasts long too. Running it at max peak rpm will lead to the shortest useful life of the piston and sleeve. If racing that is fine but if you are just playing you may want to run just a little richer than that peak setting. After the HSN is set then it is time to set the low and/or mid range needles and idling setting.
I see a lot of people idle the engine for a tank and then they let it cool off thinking that they are "heat cycling" it. However, because they are not running it up to WOT it is not generating enough heat to be of any use to a break-in/heat cycle. So, inadvertently by idling they are just letting the engine sleeve and piston wear away from the cold tight fit that they are allowing to happen when idling away on the bench. Research has shown that basically no break-in effect takes place AT ALL unless the engine is allowed to come up to operating temp for 2 minutes. So if you are idling away and then let it cool there is zero break-in/heat cycle benefit. But if you want to wear away the sleeve and piston fit then idling will definitely do it for you.
As you’ve read, there are a number of reasons why I disagree with conventional break-in methods, but the most important are:
1) Heat cycling- rich and slow means not enough heat.
2) Aluminum connecting rod stretches. If you break in a motor with aluminum rods at low RPMs, and begin the mating of the piston and sleeve (since r/c motors don't have rings), then when you go to WOT the piston actually goes higher than it did during break-in and begins to destroy the surfaces not used.
AFM
afm is offline   Reply With Quote
Old 12-22-2006, 12:40 AM   #1867
M7H
M7H's Avatar
I still have more faith in this WOT methode:....
http://www.cefx.net/tips/nitro/break-in/index.php
Serpent
M7H is offline   Reply With Quote
Old 12-26-2006, 04:28 PM   #1868
Trader Rating: 92 (100%+)
Default heat cycling
I have used the josh cyrul method on the last 5 engines now and they have ran better and lasted longer than any other engines i ever had! When you use his method they get barely warm until you start the 4th tank so i don't believe in heat cycling . I would say use whatever works for you. One more plus on the cyrul method is you can do it in a very short time.
latemodel13 is offline   Reply With Quote
Old 12-27-2006, 06:51 PM   #1869
evo1's Avatar
Default plus 12-3 sct
Does anyone have the specs on this engine,Plus-12-3sct thinking of getting one just wondering if its worth the extra cost.
evo1 is offline   Reply With Quote
Old 12-27-2006, 09:33 PM   #1870
uniquexme's Avatar
Send a message via MSN to uniquexme Send a message via Yahoo to uniquexme Send a message via Skype™ to uniquexme
may i know the difference between 12-3CT & 12-3SCT?
uniquexme is offline   Reply With Quote
Old 12-28-2006, 08:21 AM   #1871
afm
afm's Avatar
The CT uses 11.5mm crankshaft diameter.
The SCT engine uses the newer 11.9mm Crankshaft diameter. This allows the inner bore to be slightly bigger than before. The SCT engine also comes with a new head button which has a rubber O-Ring to seal out dirt from the underhead area.
AFM
Old 12-28-2006, 09:25 AM   #1872
Default 12-3SCT
Who carries this version of this motor???
jfro6512 is offline   Reply With Quote
Old 12-28-2006, 10:34 AM   #1873
afm
afm's Avatar
Murnan Modified carries the Novarrosi TOP brand of this engine in stock and modified versions. Check his web site: www.murnanmodified.com
AFM
Old 12-28-2006, 04:52 PM   #1874
uniquexme's Avatar
ok thanks, now i know. but would the new 11.9 bearing difficult to find?
Old 12-29-2006, 06:12 PM   #1875
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Here's a picture of my Nova 12+3 SCT egnine All I can say is that this engine is stupid fast
doki_doki is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
