Like Tree32Likes
Old 11-29-2006, 12:22 AM   #1831
M7H
M7H's Avatar
Originally Posted by ziggy12345
EFRA has now changed to be inline with IFMAR and so the dutch regs are NOT inline with EFRA. They are the same as the BRCA except we allow the CRF
Cheers
With this exeption, that our yearly meeting still needs to be
held, so the regulations will change, as you could read in my previous message, I was talking about the old regulations.....
Serpent
M7H is offline   Reply With Quote
Old 11-29-2006, 01:17 AM   #1832
ziggy12345's Avatar
M7H...
I like your sig. What was he using? All the crap he had left over after making everybody else??
LOL
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 11-29-2006, 02:10 AM   #1833
M7H
M7H's Avatar
No, he saved the best for last.........
The crap, he saved for our neighbours......
Serpent
Old 11-29-2006, 11:00 AM   #1834
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I thought the NS12 S3 was a short stroke engine
Cheers
You are right. They are both short stroke engines.
Corey: I know what Uriah says about the timing. I believe what Mugen and Novarossi say. They say the engines are the same. I had both and they ran the same for me. Either way, the NS12S3 is a good engine.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 11-29-2006, 01:10 PM   #1835
jag
jag's Avatar
Originally Posted by afm
ABOUT TURBO GLOW PLUGS
Turbo Glow Plugs where designed to give more performance to an engine, for the following reasons:
·It forms an uninterrupted combustion chamber.
·The advantage of better heat transfer or heat dissipation, and a leak proof seal, generated by the conical seat of the plug.
·Greater choice of thermal ranges, that allow for more precise tuning according to variations in weather conditions (temperature, humidity, altitude, barometric pressure, etc.).
The numbers and characters on the plugs, are the product number, wire thickness, and thermal range of the plug’s body. Example: The Novarossi C6TG (F) or (C)
§ Product: C (Conical)
§ Wire Thickness: 6
§ Plug Type: T (Turbo)
§ Plated: G (Gold)
§ Thermal Range: F (Fredda = Cold) C (Calda = Hot)
The plugs with cold thermal range F (Fredda), have a body with thinner walls and shorter body, so they dissipate heat better and faster to the engine head. The plugs with hot thermal range C (Calda), have a body with thicker walls and longer body, so they dissipate heat better and faster to the engine head. The number of threads is the same on both types of plugs.
How to select the proper plug:
·When the ambient temperature is high, we have to use a plug with thicker wire.
·With higher compression, we have to use a plug with thicker wire.
·Humidity determines if we use a Cold (F) thermal range, or Hot (C) thermal range.
·With high humidity percentage we should use a Hot (C) thermal range plug.
·If we have high temperature and high humidity, we should use a plug with thick wire and a Hot(C) thermal range.
The best instrument to determine which Turbo Plug to use, is those table digital weather stations, that have Temperature, Humidity, and some also Barometric Pressure on them. That is the key to success or failure tuning engines with Turbo Glow Plugs, because they are so sensitive to weather variations that is unbelievable.
Following is a selection chart for Novarossi Turbo Glow Plugs
Type Thermal Range Nitro% Air Temp.C° Humidity
C5TGC Hot/hot wire 10-20 0-10 70-100
C6TGC Hot/average wire 10-20 10-16 70-100
C7TGC Hot/cold wire 20-30 16-25 70-100
C8TGC Hot/ultra cold wire 30-up 25-up 70-100
C5TGF Cold/hot wire 10-20 0-10 40-70
C6TGF Cold/average wire 10-20 10-15 40-70
C7TGF Cold/cold wire 20-30 16-25 40-70
C8TGF Cold/ultra cold wire30-up 25-up 40-70
Hope it helps
AFM
Thanks, that is very useful information.
So if I am using 30% nitro with an average temp of around 80 degrees (F) and a relative humidity between 70% and 100% your table would recommend a C7TC (I cannot afford the gold plated plugs). Do you agree?
Thanks for the help.
Jim
jag is offline   Reply With Quote
Old 11-30-2006, 11:18 PM   #1836
Trader Rating: 12 (93%+)
Default novarossi top 8/sn??
hi
anyone heard of this .21 engine? was given to me by lhs to test out if i liked it but upon opening up it looks very simple..3port design, abc construction, slide carb, standard 1 piece head.
is this engine competitive? looks like its a basic .21 that will not produce much better..then again it may be a terror?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 12-01-2006, 05:58 AM   #1837
afm
afm's Avatar
Jim
Right....weather in Florida is like our summer, so we've been using C7T's for ages...just be carefull with humidity % Use C's for over 70% and F's for under 70%.
AFM
afm is offline   Reply With Quote
Old 12-01-2006, 05:32 PM   #1838
jag
jag's Avatar
AFM
Thanks. I appreciate the help.
Old 12-04-2006, 06:10 AM   #1839
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
guys: any feedbacks on the nova plus 12-3ct? are the ceramic bearings durable? how about run time? thanks
doki_doki is offline   Reply With Quote
Old 12-04-2006, 06:17 AM   #1840
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
i make just over 5min with the Murnan Mod on 16%
mines still 2 new to know about the bearings being durable or not but having be a nova part im sure they didnt skimp on quality
no other .12 come close in my opinon
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 12-04-2006, 06:26 AM   #1841
doki_doki's Avatar
thanks... i'm looking at the 12+3 sct version. haven't had any experience with ceramic bearings. that's why i'm asking for any opinions or feedback about this..
Old 12-04-2006, 11:50 PM   #1842
gashuffer's Avatar
Trader Rating: 48 (100%+)
Post Looking for a engine
Heys guys whats a good engine for racing. I have a sirio .21 6 port but i have some cash to burn? I want to keep the Sirio for a back up. 450- 500 area?
gashuffer is offline   Reply With Quote
Old 12-05-2006, 02:35 PM   #1843
I just got a plus 12-3ct for x'mas gift. (I know it is not yet the time. But, I cannot wait to open it up). I let you know after finishing breakin
silverM3 is offline   Reply With Quote
Old 12-05-2006, 02:57 PM   #1844
The Plus 12-3 SCT is different to the Plus 12-3CT. Both have ceramic bearings, but the SCT has a different diameter crank and bearing. It is 11.9mm rather than 11.5mm diameter. I've been running one for the last few weeks and it is gun.
Also, after extensive testing with pipes, we found the Novarossi 2630 to be the best! The pipes tested were, Mugen 2501, Sirio 2611, Novarossi 2601, 2602, RB 2604, Skyline VR12, VR12 Plus.
Rody is offline   Reply With Quote
Old 12-06-2006, 02:07 AM   #1845
jaykay's Avatar
thats right, the 2630 pipe seems to be the best for the plus. i use it with the short (5 fins) manifold.
Darren Johnson has used on the Euro 2006 in Heemstede the 2601 pipe with the short (5fins) manifold. I talked to him and he said that the bottom power is much better with the 2601. He also said, that it´s more important to change your gear transmission.
jaykay is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 5 (3 members and 2 guests)
Dougie1986
