Old 11-25-2006, 07:57 AM   #1816
cdelong's Avatar
Originally Posted by Scott Fisher
Good engine. Long stroke. There is general info on Nova's website. The Mugen X12 is the same engine as that one.
Murnan says the timings on the Mugen X-12 and the NS12 S3/A1 are significantly different. I know all the parts are the same but the timings are not.
I have had both and personally preferred the Mugen X-12.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 11-25-2006, 08:13 AM   #1817
ziggy12345's Avatar
I thought the NS12 S3 was a short stroke engine
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 11-25-2006, 08:16 AM   #1818
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Originally Posted by M7H
Yep
IFMAR is International federation
EFRA is European Federation
ROAR is USA
NOMAC is Dutch
BRCA is Britsch
And I recon that every country has it's own national organisation......
cheers man always count on on someone
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 11-25-2006, 08:20 AM   #1819
as soon as i can find my camera ill post some pic of my Murnan PLUS-12CT lol
Futaba
Mugen
Novarossi
Byron's
Old 11-25-2006, 03:33 PM   #1820
jag
jag's Avatar
Default Glow Plugs
What's the difference between the "long body" and "short body" C vs. F? More importantly, which one should I be using in my Rex RER?
jag is offline   Reply With Quote
Old 11-25-2006, 05:47 PM   #1821
DS Motorsport's Avatar
Ziggy, it's about time that the BRCA helds it's meeting after the EFRA meeting, because for 2007 you guys might not be able to use new engines, because they are all BRCA illegal.
Or am I missing something?
M7H do you know if the new efra rules, allowing the turbo scoop, also count for nomac?.
I've looked for it but couldn't find a answer anywhere.
But if it's so it;s a good change because it means more power.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-27-2006, 11:18 AM   #1822
afm
afm's Avatar
ABOUT TURBO GLOW PLUGS
Turbo Glow Plugs where designed to give more performance to an engine, for the following reasons:
·It forms an uninterrupted combustion chamber.
·The advantage of better heat transfer or heat dissipation, and a leak proof seal, generated by the conical seat of the plug.
·Greater choice of thermal ranges, that allow for more precise tuning according to variations in weather conditions (temperature, humidity, altitude, barometric pressure, etc.).
The numbers and characters on the plugs, are the product number, wire thickness, and thermal range of the plug’s body. Example: The Novarossi C6TG (F) or (C)
§ Product: C (Conical)
§ Wire Thickness: 6
§ Plug Type: T (Turbo)
§ Plated: G (Gold)
§ Thermal Range: F (Fredda = Cold) C (Calda = Hot)
The plugs with cold thermal range F (Fredda), have a body with thinner walls and shorter body, so they dissipate heat better and faster to the engine head. The plugs with hot thermal range C (Calda), have a body with thicker walls and longer body, so they dissipate heat better and faster to the engine head. The number of threads is the same on both types of plugs.
How to select the proper plug:
·When the ambient temperature is high, we have to use a plug with thicker wire.
·With higher compression, we have to use a plug with thicker wire.
·Humidity determines if we use a Cold (F) thermal range, or Hot (C) thermal range.
·With high humidity percentage we should use a Hot (C) thermal range plug.
·If we have high temperature and high humidity, we should use a plug with thick wire and a Hot(C) thermal range.
The best instrument to determine which Turbo Plug to use, is those table digital weather stations, that have Temperature, Humidity, and some also Barometric Pressure on them. That is the key to success or failure tuning engines with Turbo Glow Plugs, because they are so sensitive to weather variations that is unbelievable.
Following is a selection chart for Novarossi Turbo Glow Plugs
Type Thermal Range Nitro% Air Temp.C° Humidity
C5TGC Hot/hot wire 10-20 0-10 70-100
C6TGC Hot/average wire 10-20 10-16 70-100
C7TGC Hot/cold wire 20-30 16-25 70-100
C8TGC Hot/ultra cold wire 30-up 25-up 70-100
C5TGF Cold/hot wire 10-20 0-10 40-70
C6TGF Cold/average wire 10-20 10-15 40-70
C7TGF Cold/cold wire 20-30 16-25 40-70
C8TGF Cold/ultra cold wire30-up 25-up 40-70
Hope it helps
AFM
afm is offline   Reply With Quote
Old 11-27-2006, 12:22 PM   #1823
M7H
M7H's Avatar
I've sent you a PM....
In general (for people who are interested) the Dutch regulations are the same as EFRA, which means a so called "turbo scoop" is allowed but it can not end (or begin) in the crankhole.
The crankhole (and don't forget this is the old rule!) has a max diameter of 7mm, and should be perpendicular (90 degrees) on the rotation axis (WASP REV not allowed!!!)
Also the end of the hole near the backplate should be continously round, with a max rounding (chamfer) of 0.5mm, so the turboscoop can not be a part of the hole. NOMAC regulation.: 11.1.3 (jaarboek 2006 pagina 11.3)
Serpent
M7H is offline   Reply With Quote
Old 11-28-2006, 01:38 PM   #1824
gashuffer's Avatar
Trader Rating: 48 (100%+)
Default Axe Rossi
Hey guys I am new to this sport/hobby and I was given a new Rossi engine with a red crank case. Are these any good for racing? Are these good engines in general? This is my first 1/8 scale car. I raced indoor electric 1/12 scale years ago and I am just getting back into this hobby.
gashuffer is offline   Reply With Quote
Old 11-28-2006, 07:06 PM   #1825
Regional Moderator
daniz24's Avatar
Rossi engines are different than Novarossi. Sorry no experience with Rossi engines
daniz24 is offline   Reply With Quote
Old 11-28-2006, 09:08 PM   #1826
gashuffer's Avatar
Default Rossi
I figured this is the only rossi related thread and they are in a way cousins Maybe someone has a little experience with them.
Old 11-28-2006, 09:17 PM   #1827
occ
Trader Rating: 15 (100%+)
They would be ok for racing but it depends on what racing you mean. Club days, major events etc. They are not that popular at major events, in fact I have never seen them used where I am from...
Run it till it blows up then just get either a novarossi based engine which includes RB, JP or try the Ninja or Sirio.
occ is offline   Reply With Quote
Old 11-28-2006, 09:28 PM   #1828
gashuffer's Avatar
Default Rossi Engines
Thanks of the reply. I kind of figured that. I have a brand new modded Sirio that I can't wait to break in after I run that Rossi into the ground It was a freebe so I can't complain. Never saw one of those engines before until it was given to me.
Old 11-29-2006, 12:48 AM   #1829
ziggy12345's Avatar
The engine you have is the Rossi R21 Maranello. It is now sold under the AXE brand. Its still a good little motor and will last forevever.
Cheers
Sponsored by:
Norfolk and Chance
Old 11-29-2006, 12:52 AM   #1830
ziggy12345's Avatar
EFRA has now changed to be inline with IFMAR and so the dutch regs are NOT inline with EFRA. They are the same as the BRCA except we allow the CRF
Cheers
Sponsored by:
Norfolk and Chance
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
SEO by vBSEO 3.5.0
