Like Tree22Likes
Old 10-02-2006, 07:48 AM   #1711
Bad Mika's Avatar
Hi Guys...
I've noticed there is a Plus 12-5CT and 12-5SCT. Any idea what the S stands for ? Thanks !
Bad Mika is offline   Reply With Quote
Old 10-02-2006, 08:21 AM   #1712
madbeats's Avatar
Default PLUS12 is the strongest engine in its class
Originally Posted by Bad Mika
Hi Guys...
To your ? PLUS12-5ST (steel bearing)
PLUS12-5SCT (ceramic bearing)
hope that help..
Serpent 966/720 Mugen MTX4R Xray NT1-Mugen MTX-4 Knack R conversion Hong Nor X1CR
madbeats is offline   Reply With Quote
Old 10-02-2006, 05:36 PM   #1713
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
S = stiff, due to the new crankshaft which is 11.9mm diameter.......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 10-02-2006, 06:24 PM   #1714
madbeats's Avatar
Default ere did you get your infor ?
Are u Mr Novarossi
were did you get your infor ?
Old 10-03-2006, 12:10 AM   #1715
ziggy12345's Avatar
When are Novarossi and all the other engine manufacturers going to show the real HP figures for an engine? 1.68HP??? The max anybody has got from a .12 engine is 1.15 and that was the CRF WASP.
If I bought a car from BMW and it said it was 500Hp and I put it on a rolling rd and it came out as 280BHP I think i would take the car back and get my money back. BMW would also face a legal bill
So where on earth do this figures come from? Is there some sort of disclaimer on the box in microscopic print stating "HP figure is for 0.0001sec duration when using nitroglyserine as fuel at 500 dec C just before engine explodes"
They might as well say the thing has a 1,000,000 HP and does a zillion RPM as it means about the same.
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-03-2006, 04:04 AM   #1716
asw7576's Avatar
I'm not even sure a micro engine REALLY make 1 HP.
http://auto.howstuffworks.com/horsepower.htm
Old 10-03-2006, 05:27 AM   #1717
Bad Mika's Avatar
hope that help..
Hi Madbeats... thanks for the reply.
However, still don't ring a bell... it shows Plus 12-5SCT and not 5ST. And it costs US$16 more than the Plus 12-5CT which should be on ceramics...
Old 10-03-2006, 05:36 AM   #1718
ziggy12345's Avatar
Dynomometer test show only the CRF wasp making more than 1 HP (1.15) out of all the standard engines. A BRB set made 1.01 HP and the Murnan Moded motors show around 1.05 HP
Mostly the Out of the Box motors will run from 0.6 to 0.9 HP and that inludes the Novas
Cheers
Sponsored by:
Norfolk and Chance
Old 10-03-2006, 08:59 AM   #1719
afm
afm's Avatar
Originally Posted by ziggy12345
When are Novarossi and all the other engine manufacturers going to show the real HP figures for an engine? 1.68HP??? The max anybody has got from a .12 engine is 1.15 and that was the CRF WASP..............
So where on earth do this figures come from? ...............
They will keep on doing so until there is an industry standard for measuring HP.
What Nitrodyne Systems does is apply SAE correction factors to their measurements, that take into account weather conditions (Air temp, humidity, altitude, etc,etc.). Also same Nitro % on all engines, and they tell you which pipe was used on the test.
Also you would have to shim all engines accordingly to their best on whatever nitro % is used, and to compare there should a be a run with defined pipe for all engines, and another run with the best pipe of the manufacturer. Also, all manufacturers should use same Dyno.
In the mean time Manufacturers should state the method used to get those raw and ridicoulos numbers.
I Think that the best way to get real numbers would be if main governing organizations like EFRA, ROAR, IFMAR, demand that manufacturers must submit spec sheets for homologation, with a defined method of measurement. Just like pipes and bodies....if they don't...bye bye baby.
AFM
afm is offline   Reply With Quote
Old 10-03-2006, 09:10 AM   #1720
it makes me wonder how we saw 4 different engine brands making the WC main final............
the only 1.15hp engine wasn't any faster than the others (fast in laptime, please don't tell me that the top speed at the end of the straight was achieved by the CRF engine because I've read the post informing that).........
every manufacturer has its parameter for estimate power and rpm..........if the nitro dyne systems become a standard then the measuring process should have a standard mode as well..........most engine were tested with a X pipe/header and with 30% nitro fuel...........
every engine has an exhaust system properly designed for best performance............and every .12engine is designed to run with 16%nitro.......IMO these are 2 important parameter, not to mention a room with controlled temp, humidity and pressure..........
I also would prefer an engine being dyno'ed installed on a car an then get the power on the driven wheels.........
Salvadori Racing
Old 10-05-2006, 05:57 PM   #1721
mugenb46's Avatar
sup guys can anyone tell me if the sg crank out of an MT12 will work in a cx12. i want a cx 12 for my gt2 but don't want to have to run a threaded shaft that comes with it. i have a mt12 sg crank i would like to try to put in it if it will work.
mugenb46 is offline   Reply With Quote
Old 10-05-2006, 05:59 PM   #1722
AMGRacer's Avatar
It works.
AMGRacer is offline   Reply With Quote
Old 10-05-2006, 06:10 PM   #1723
mugenb46's Avatar
thanks bud, just pull out threaded crank and place in the sg crank, nothing else to change, cx conrod and all stays the same correct.
Old 10-05-2006, 06:23 PM   #1724
AMGRacer's Avatar
Yep. I used a MT12 crank in a CX12 because it had better timing. Works perfectly well with the stock rod and piston.
Old 10-05-2006, 06:30 PM   #1725
mugenb46's Avatar
thx amgracer
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
