Like Tree8Likes
Old 09-22-2006, 10:06 AM   #1666
mtveten's Avatar
Trader Rating: 27 (100%+)
Yep the TZ is a good motor. If you liked the LL better aside from its slowdown in the middle you should try the LS tuned it has feels kinda like an LL that doesn't lose its snap around the shift point.
mtveten is offline   Reply With Quote
Old 09-22-2006, 03:22 PM   #1667
hav_lova's Avatar
I'll look into it, as i said that was its only downfall it seemed to lose that magic down the straight
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 09-24-2006, 02:32 AM   #1668
Default RX21R1WC conrod replacing
Hi guys,
Can anyone pls help me out... i think it's time to check for the conrod for replacement... the rod have not been change since new... how do u guys do the checking for replacement?? (i lost count of the usage cos i run 2 engines hehe...)
Can i use the R5 conrod instead of the R4?? cant find the R4 rod at my LHS...
thanks
ck
ck960 is offline   Reply With Quote
Old 09-24-2006, 07:50 AM   #1669
Default run in..help
hi,everyone i just get myself a REX rer5p,now im runing in with 25%nitro...do i need to add a 0.1mm shim?coz one of my frend said is better to add a 0.1 shim but my pervious rb x12 i din add and also doing good....ok hope u guy can gave me some comment......tks
tohtw is offline   Reply With Quote
Old 09-26-2006, 02:32 AM   #1670
Iv had both the LL3 and the LS3 and found the LS3 to be the better engine for me out of the two.
Ive also just run the MF 12 3P MasMo Version 2 and this thing is just another level and would be the best buy at the min.(see link)
http://www.mytsn.com/products/desc.asp?prid=4349
Nick Simpson is offline   Reply With Quote
Old 09-26-2006, 04:00 AM   #1671
aaalp's Avatar
Send a message via ICQ to aaalp Send a message via MSN to aaalp Send a message via Yahoo to aaalp
Default N12LS3
Guys,
I am running an N12LS3. The engine had no problem when the weather was hot. Now that it cooled down, I am having problems with the fine tuning.
When I start the engine, idle is fine. It pulls off without hesitation. Hit the top rpm on the straight or give full throttle in between and then come into the corner, it still wants to rev, the rpm doesn't drop immediately.
If I come to a full stop on the straight from high rpm, the rpm comes down but reaches a steady idle after let's say 5-10 sec.
Any suggestions where I should adjust?
aaalp is offline   Reply With Quote
Old 09-26-2006, 06:22 AM   #1672
hav_lova's Avatar
Sounds lean on the top end? whats it temp at? remember you should always run a few laps and tune the engine once its at race temps
serpentrc.com.au
Old 09-26-2006, 08:11 AM   #1673
Send a message via MSN to Qlone
aaalp: The top end sounds too lean. The engine now needs some time to 'refill' with fuel after a full throttle burst and can't get enough fuel at its (still) high RPM to do so. If you go any leaner you will probably notice it making some sound as it starves for fuel on the straight.
The drop in RPM after idling for a while is related to this. Your bottom end adjustment probably is almost correct but takes a while to come into effect because the engine is still 'refilling'.
Try richening up the HSN by about 1/3th of a turn...
Qlone is offline   Reply With Quote
Old 09-26-2006, 09:22 AM   #1674
Xyvern's Avatar
i just looked at novarossi website, a bit confuse because of so many type of .12 engine.
just wondering, which one is the best for high speed track with 2 sweepers?
Novarossi Plus 12-3CT
Xyvern is offline   Reply With Quote
Old 09-26-2006, 09:28 AM   #1675
Team Kamikaze's Avatar
Maxy modified Plus 12-3CT SAN PIE PA SHAE OOH
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-26-2006, 05:35 PM   #1676
Default pls help with R01 WC conrod
Anyone can input thanks...
ck
Old 09-26-2006, 06:56 PM   #1677
JOSE CASAS's Avatar
I RECOMMEND THE NOVA 12-PLUS 3CT STOCK. MOD MOTOR MIGHT HAVE DIFFICULTY MAKING 5 MINS.
RC America / X-Ray / Hudy / Pro level RC / Red Line fuel
JOSE CASAS is offline   Reply With Quote
Old 09-26-2006, 07:35 PM   #1678
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
5 MIN IS FINE WITH FULLY MODED PLUS 12-3CT
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 09-26-2006, 08:36 PM   #1679
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Scott Fisher
I think the LS is better in all cases. I did not like the LL engine
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-26-2006, 09:51 PM   #1680
ck
Yes you can it has the same spec. and the R5 is actually an improved version of R4, you can also use R7 which is the better version of R5.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
