Old 06-30-2006, 11:26 PM   #1531
cool thanks. i think i will get the vantage pipe because it looks good and is only $60.
basher772000 is offline   Reply With Quote
Old 07-01-2006, 05:13 AM   #1532
evo1's Avatar
Default nsr12s3 tuned
Hi i have the chance to buy a nsr12s3 factory tuned motor. Can anyone tell me when they stoped producing this engine.The engine is new in box and a good price. What mods are done for a factory tuned engine? . Not sure whether to go this way or go for the plus 12-3, any help would be good.
Thanks Paul
evo1 is offline   Reply With Quote
Old 07-01-2006, 07:56 AM   #1533
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Thanks Paul
this engine is still produced........
novarossi tuned versions have milled crankshaft with silicone insert.....
the sleeve has some work on exhaust port
and the piston/sleeve set is specially selected.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 07-01-2006, 10:10 AM   #1534
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
any one tried the JP mod plus 12-3CT how dose it go any one know
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 07-02-2006, 01:11 PM   #1535
jaykay's Avatar
Today I have break in my new Novarossi Plus 12-3. The performance of the engine is very good, but i have problem when the engine is off. I run it with 100 degress and when the engine get off and i want it to turn off it needs to long. the caburetor is too hot.
jaykay is offline   Reply With Quote
Old 07-03-2006, 05:16 AM   #1536
evo1's Avatar
Thanks for that . what is a good pipe to use with this motor.
Old 07-03-2006, 01:02 PM   #1537
ziggy12345's Avatar
Sounds like its running too hot. Check your temp gun, it might be reading wrong
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-04-2006, 04:37 AM   #1538
i want to buy a new engine and cant chose witch one to buy can some one help its between a Murnam moded plus 12-3ct at $389(USD) or the JP moded verson at $410(USD) any info that would help me decide would be great
Futaba
Mugen
Novarossi
Byron's
Old 07-04-2006, 08:52 AM   #1539
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
Both are Nova base so Try Murnan
suntok2 is offline   Reply With Quote
Old 07-04-2006, 09:06 AM   #1540
i think ill go with Murnam's it just when you hear JP&Nova it sounds like the holy grail
Futaba
Mugen
Novarossi
Byron's
Old 07-04-2006, 09:22 AM   #1541
Default orings
There are two orings that are used to seal the carb on the nsr 12 s3.one slips on the barrel of the carb and the other mounts in the crank case at the bottom of the carb barrel.I am looking for the one thats sitting in the crank case. rc mushroom has orings but nothing for the lower or upper carb barrel oring.any help would be greatly appreciated .
fasteddie d is offline   Reply With Quote
Old 07-07-2006, 03:16 AM   #1542
evo1's Avatar
Hi there , i have a nsrs3 factory tuned motor. What would be a good pipe to use on this motor our track has a fairly long straight with a couple of tight sections on the infield .Car is a serpent 710
Regards Paul
Old 07-17-2006, 12:19 PM   #1543
rushdude's Avatar
Send a message via AIM to rushdude
I need some help. I have a novarossi tsr12s3. I am having trouble with glow plugs. One plug only lasts about 4 tanks if i am lucky. I have been using novarossi #7 plugs. I am using trinity monster horse power fuel. 20% nitro 18% oil. On one of the bad plugs i noticed that the wire was like cut. Almost like someone cut it with a pair of wire cutters. I havent had any part of the coil fall into the engine though and it was only one plug that was damaged. On the other plugs there were black residue on the tips that wiped off very easily with a finger or towell.
As for head shims, i only have the aluminum one which is .3mm like stated in a previous post on this thread about running 20% nitro. Should I add another .1mm shim or is it something else?
rushdude is offline   Reply With Quote
Old 07-17-2006, 12:39 PM   #1544
Corse-R's Avatar
Much probably your conrod is shot and this kills plugs, check it for wear and damage, change it at the least suspect of wear.
Adding a 0.1mm shim could be beneficial because if you're racing near the sea level with lots of humidity you need to make room for that extra humidity on the combustion chamber.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-17-2006, 12:54 PM   #1545
rushdude's Avatar
I will check the con-rod tonight for signs of wear. What would i be looking for exactly? Stretched? I am near sea level too, so if the conrod looks good i will add another shim and give it a try.
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 11:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 11:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 06:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 07:28 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
RoketRdr
SEO by vBSEO 3.5.0
