Like Tree8Likes
Old 06-24-2006, 06:22 AM   #1516
iwk2much's Avatar
Originally Posted by silverM3
Anyone have any exp. on Plus12-3 ? I am torn between it and OS 12 TZ tuned. Any comments would be appreciated!
SilverM3:
I used this motor (12-3CT)for the nats last week. It has a large power window and easily made time despite not being fully broken in. Comparing it to OS Speed motors at the track, this motor had better rip at the bottom and mid range but lost out a little in the top. I was geared for this and didn't have time to experiment with pipes. On top of the great power and mileage this unit gave me, after a gallon or so of fuel, the motor could still use some running in. I predict this motor will last quite a while. Hope this helps.
Mike Strack
iwk2much is offline   Reply With Quote
Old 06-25-2006, 01:51 PM   #1517
MAXNITRO's Avatar
Do i need to replace the crank if i convert the LS5 to an LS3? or just the Piston & liner?
MAXNITRO is offline   Reply With Quote
Old 06-25-2006, 03:55 PM   #1518
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Originally Posted by iwk2much
SilverM3:
did you use the EFRA 2630 exhaust pipe???
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 06-25-2006, 03:58 PM   #1519
piston/sleeve only.....
Salvadori Racing
Old 06-26-2006, 02:59 AM   #1520
rcabj's Avatar
i've just drop in a 3port p/s into my 3 year old nova s5...without replacing any other parts...after doin some breakin in and raced it yesterday it works pretty well...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 06-27-2006, 09:55 AM   #1521
ziggy12345's Avatar
The OS is not a true ABC PL set and will loose the pinch very quickly if overheated. Go for the 12-3
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-27-2006, 10:22 AM   #1522
afm
afm's Avatar
Cheers
What do you mean it's not "True ABC" ?? The Specs for the engine says so:
FEATURES:
-Natural aluminum construction Nine fin blue aluminum cooling head
-Two-piece turbo cylinder head with 29mm innner and 49mm outer head
that adds extra area for more efficient cooling
-Slide Carb 11H - 3 needle slide valve carburetor with ROAR/IFMAR legal 5.5mm carb restrictor
-Rear Exhaust
-ABC construction, Aluminum piston and Brass liner that is Chrome plated
-High tensile A7075 "knife edge" aluminum connecting rod double bushed for friction-free operation.
Donít confuse compression with pinch, Sleeve Pinch is not that important contrary to popular belief. The question is how well does it seal as soon as the piston starts to close the exhaust port and if it holds compression after you roll it to top dead center.
Place a few drops of after run oil trough the top (removing plug), then place plug in place, then roll piston to top dead center and listen and look for air bubbles through exhaust port. If thereís none, then your engine still has compression, even if it has no pinch.
The fastest team motors we have, have zero pinch.
AFM
afm is offline   Reply With Quote
Old 06-27-2006, 11:31 AM   #1523
Wink
FEATURES:
-Rear Exhaust
AFM
I am not knowledgable as anyone of you. But, my exp is that OS TZ seems to be quite durable. I had more than 8 gallons on TZ 5, and I still see a lot of compression.
My bday is coming up, and my wife finally "allows" me to buy a new engine. I like OS TZ tuned better, because I am used to tune OS engine. Plus 12-3C seems to me is a better deal, cheaper and equal in performance. But, I heard NovaRossi is harder to tune than OS engine. That is why I would to hear some comments regarding these to engines. Thx.
silverM3 is offline   Reply With Quote
Old 06-27-2006, 04:42 PM   #1524
teammpp's Avatar
Cheers
Not sure were you are getting that info but OS probably make one of the finest ABC P/L ever. Granted they were never huge on the car scene other than off-road compared to other known brands but their aero engines have been the class leaders for many decades.
teammpp is offline   Reply With Quote
Old 06-29-2006, 01:40 AM   #1525
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
any one know the difference between all the the 12 plus 3 models
is it turbo non turbo ceramic and non ceramic is this right
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 06-29-2006, 05:15 AM   #1526
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
yes,
plus 12 - 3 (non-ceramic, non-turbo)
plus 12 - 3C (ceramic, non-turbo )
plus 12 - 3T (non-ceramic, turbo)
plus 12 - 3cT (ceramic, turbo)
1603 - non-ceramic rear bearing
1606 - ceramic rear bearing
FREELANCE_RCer is offline   Reply With Quote
Old 06-29-2006, 06:51 AM   #1527
iwk2much's Avatar
No, I used a JP EFRA 2620. Ddin't have time to test the 2630.
Mike Strack
Old 06-29-2006, 07:58 AM   #1528
Originally Posted by FREELANCE_RCer
yes,
just to clarify......
when Novarossi means NON TURBO, it refers to the crankshaft, not the glowplug, the non turbo shaft is EFRA legal and its tunel is smaller than the turbo style, which is not efra legal.......
Salvadori Racing
Old 06-30-2006, 10:00 PM   #1529
ok guys i have a Novarossi RR12L3 hotmod engine. What is a good pipe and header combo for it?
basher772000 is offline   Reply With Quote
Old 06-30-2006, 10:12 PM   #1530
Team Kamikaze's Avatar
Here is the list that you can choose from
JP EFRA 2620
Nova Rossi EFRA 2630
Skyline VR 12 Plus ROAR LEGAL
Vantage carbon pipe ROAR LEGAL
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
