Like Tree8Likes
Old 06-19-2006, 04:17 AM   #1501
anyone know the stock carb settings on 421 bnx buggy eng?
reddishdsb is offline   Reply With Quote
Old 06-19-2006, 09:50 PM   #1502
antoine80's Avatar
Originally Posted by markoshark
I have a Novarossi TSR12S3, and was wondering if anyone knew the default carb settings for it?
i did it yesterday i used a material i found here, it is like thin silicone but is used for sealing pipes, it can "survive" in high temperatures and under any fuel contact
the engine improved the way it is working, although it doesn't drop the RPM immediately after you return the throtle to idle position, it takes some time less than before. Also the temperature of the engine droped some degrees C.
today (i think..) i will receive the o-rings for the tuning niddles in the engine so i will replace them too.. i have this will seal the engine totaly.
thnx for your help
antoine80 is offline   Reply With Quote
Old 06-20-2006, 04:04 AM   #1503
jaykay's Avatar
what kind of exhaust system do you use on a long stroke engine?
i´m going to buy me the new NOVAROSSI PLUS 12-3 and it´s a long stroke engine.
jaykay is offline   Reply With Quote
Old 06-20-2006, 08:23 AM   #1504
stefan's Avatar
Send a message via AIM to stefan
Mielke 2501 mit kurzem konischen Krümmer geht auf meinem R12L3 gigantisch.
Schreib mir doch mal eien PM wenn du den Motor gefahren bist, würde mich sehr interessieren wie der so geht.
Ach ja, und wo kriegts du den Motor her und für wieviel?
Gruß, Stefan
stefan is offline   Reply With Quote
Old 06-20-2006, 09:30 AM   #1505
hi stefan,
hast du noch was an deinem motor gemacht.
wir haben 2 jungs die hatten schon keine kompression mehr
nach ca. 3 liter.
dieter
sorry guys for writing in german
4racer is offline   Reply With Quote
Old 06-20-2006, 09:47 AM   #1506
stefan's Avatar
Originally Posted by 4racer
hi stefan,
nach ca. 3 liter.
dieter
Hallo Dieter, ja meiner hat das volle SMG-Programm und geht gewaltig
Ich habe meine eigene Methode die microcasted Motoren einlaufen zu lassen und die hat sich hervoragend bewährt. Meine ersten beiden haben auch sehr bald Kompression verloren, nun nicht mehr.
Old 06-20-2006, 10:30 AM   #1507
yes I have the same question. I have 52607 pipe set sitting around. Would this be a good match?
Also, can someone plz shed some light on how Plus12-3 compare to OS speed 12 TZ tuned?
silverM3 is offline   Reply With Quote
Old 06-20-2006, 08:05 PM   #1508
Default Pipe for 35 plus 21
Can anybody recommend a good pipe for the Novarossi 35 plus 21? Thanks
no4hitter is offline   Reply With Quote
Old 06-21-2006, 12:57 AM   #1509
team novarossi's Avatar
Send a message via MSN to team novarossi
the 2052 with the five fin conical manifold is very good combo!
team novarossi is offline   Reply With Quote
Old 06-21-2006, 04:43 AM   #1510
PROVK's Avatar
Trader Rating: 14 (100%+)
I just received a Novarossi 2630 pipe and have noticed that the
inlet to the pipe is a smaller diameter than my mugen and max/nova pipe.
2630 fits loosely into my mugen and max/nova header.
Do I need a different header or is it supposed to be loose?
PROVK is offline   Reply With Quote
Old 06-21-2006, 06:11 AM   #1511
jaykay's Avatar
Gruß, Stefan
PM ist unterwegs!
Ich überleg grad ob der Dieter und ich auch das Mielke 2501 haben. Ich weiß nicht genau welches Habbecke Rohr dem Mielke entspricht
For our english speaking friends:
PM is on his way!
I´m just thinking about if Dieter and I have the Mielke 2501, too. I´m not sure which Mielke Pipe is like our Habbecke one.
Old 06-21-2006, 07:51 AM   #1512
antoine80's Avatar
Default air temperature
hey all,
do you run your engines under hight external temperatures? these part of the year here we have nearly 40 degrees C, should i protect the engine and not run it? do you have a threshold in air temperatur over which you don't run your engines?
if not is there any measure you take against the high temp?
antony
Old 06-21-2006, 06:31 PM   #1513
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
just put a #8 glow plug and let it go........
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 06-22-2006, 12:04 AM   #1514
antoine80's Avatar
thnx for the hint,
do you you change the percentage of nitro in the fuel when the temp rise? i usually run my LL5 with 16% nitro.
Old 06-24-2006, 12:05 AM   #1515
Anyone have any exp. on Plus12-3 ? I am torn between it and OS 12 TZ tuned. Any comments would be appreciated!
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 05:48 PM
RB engines thread CraigM Nitro Off-Road 7 01-05-2008 10:57 AM
JP Engines Thread DOMOisCOOL Onroad Nitro Engine Zone 2 02-16-2004 05:00 AM
OS engines thread EVOLUTION Onroad Nitro Engine Zone 44 02-11-2004 06:28 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
