Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
O.S .12TZ 5 PORT HEAD SHIM QUESTION >
Old 03-25-2009, 12:09 AM
freestyles's Avatar
Trader Rating: 14 (100%+)
Default O.S .12TZ 5 PORT HEAD SHIM QUESTION
How many head shims are you guys running. It came with a .1mm and a .2mm shim. In the manual it says when breaking in use both but when using low nitro content take the .2mm one out.
What's considered "low nitro content"?
I'm using 16% fuel with both .1mm and .2mm head shims and it seems to run ok but i want to experiment and try to get the best out of it.
Thanks, any help would be much appreciated
freestyles is offline
Old 03-25-2009, 11:33 PM
freestyles's Avatar
Bumpity bump
Old 03-26-2009, 11:00 AM
afm
afm's Avatar
On a .12 engine I would only advise going 0.10mm over or under 0.46mm, so that is 0.36mm or 0.56mm, of total head clearance.
Generally on a .12 engine 0.10mm will change the compression ratio about 3/4to 1 point..
Also, never assume that the head shim(s) that is on the engine is the actual head clearance. in many cases you will find that the engine actually has 0.20mm to 0.15mm without any head shim. Novarossi's are 0.20mm without one, and the factory installs a 0.30mm shim, giving the engine 0.50mm stock head clearance. This has not always been the case but 99% of the time it is.
When in doubt measure the head button register and the piston to the top of the liner at top dead center and subtract, to determine proper shim. This is the only way to really know.
Experience dictates that just by lowering the head (more compression) you gain more power especially in lower rpm range, idle quality can suffer, but the engine also runs cooler . Also, that a higher head (less compression) will increase top rpm speed on bigger tracks.
A decrease in head shims (an increase in compression ratio) will increase torque because as the compression ratio goes higher, the actual ignition timing occurs sooner. However there is a point of diminishing returns where detonation occurs or engine temps can soar, and if this happens a colder plug can help.
A colder plug will also increase torque, except in the instance of a colder plug the ignition is slowed until a greater point of compression build occurs.
When you increase head shims (a decrease in compression), top end is enhanced as the ignition timing is retarded and occurs later. Generally a hotter plug is needed to advance the ignition cycle so that timing does not occur to late in the cycle, but at this point you end up over leaning the engine to get it to rev properly and the engine life will suffer dramatically.
I should also state that the comments with regards to plugs and head shimming are when both are used together. Used alone a hotter plug will rev harder and a colder plug will make more torque.
For the OS TZ use .1mm shim with 16% nitro, .2mm shim with 20% nitro, and both .3mm shim with 30% nitro......now following the guidelines above, you can fine tune your engine for torque or high speed using more or less shims and changing glow plugs......with your 16% nitro, right now and with both shims, you should have plenty of top end.
Hope it hepls
AFM
afm is offline
Old 04-06-2009, 12:27 PM
kmichael's Avatar
If you use 20 percent or less use the .1 shim.Use the .2 for higher percent.I dont think it says anything in the manual about using both shims for break in,but I wouldnt thinkk thats right.Break in the motor with the shims you plan on running.
kmichael is offline
Old 04-07-2009, 04:09 AM
kmichael's Avatar
This was not my input but, infor from a friend using my laptop and was logged in under my name, not saying I agree or disagree just not my infro
kmichael is offline
Old 04-07-2009, 12:43 PM
Chickentrader's Avatar
Default Is using no head shim in O.S. engine improper/
Our club's scrutineer says that removing all head shims in the OS engine is illegal as far as he is concerned; we should only be allowed to remove one, and he will disqualify any car with no head shims from bigger events. Most of the gas drivers disagree with this ruling; and say that this action is simply a tuning procedure. What is the consensus about it on this forum? Is it improper to race with no head shims?
Kindest regards,
Lars.
Chickentrader is offline
Old 04-21-2009, 05:03 AM
Trader Rating: 101 (100%+)
Default shim rule
That's a rule that would be a nightmare to tech. All you would have to do is cut the head and add that amount of shimms back. I don't think you would want to run with n o shim though.
latemodel13 is offline
