Old 02-04-2009, 07:10 PM   #1
Default pinch a motor
new to the nitro scene(1/8 buggy)what do they mean by needing a pinch any info would be helpful thanks
bugsee2 is offline   Reply With Quote
Old 02-05-2009, 12:42 AM   #2
staikosn1's Avatar
Send a message via MSN to staikosn1
Thats a piston/sleeve resizing!! You do that when the compresion of your engine is low. After pinching you are good to go a few gallons!!(1-2)....Thats all i know!
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 02-05-2009, 04:44 AM   #3
chunk t's Avatar
Pinching is an attempt to resize the sleeve to re-establish the tight fit between the p&s at the top of the stroke. Pinching is not intended to resurect the dead; but to extend the life of the engine. So, the advise is to do mild pinchs throughout the engine's life. How often? you'd get a different answer from each driver.
Though You will find a great number of drivers who will sware by pinching... I do not subscribe to the practice.
chuck "chunk" thomas
1:10, 2-wd Stadium Trucks
B-Mod Tunnels
If ignorance is bliss... I must be in heaven!
chunk t is offline   Reply With Quote
Old 02-05-2009, 07:24 AM   #4
wizby's Avatar
I believe the sleeve is no longer round. It may feel tight at top of stroke but the seal between p&s has been comprimized. Its possible to compress brass but the chrome lining is not a malable material.
wizby is offline   Reply With Quote
Old 02-05-2009, 12:38 PM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
Pinch is the force you feel when you turn the crank around without glowplug mounted. These engines have no pistonring and the solution is a conical shaped sleeve with a slight oversized piston you have to run in zo they will shape to each other perfectly on the right temperature.
In cold conditions with most enginen some pinch is a good sign because on temperature the pinch is gone due the unequal expansion of the piston and sleeve.
Pinching is a methode to make the upper part of the sleeve smaller using a press arround the sleeve. This is only needed when the set is loosing compression.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 02-06-2009, 09:20 AM   #6
thanks all for the info-bugsee2
Old 02-06-2009, 09:27 AM   #7
joe of loath's Avatar
I had an HPI G3.0 engine repinched. It was almost as tight as new, and had a much better seal, but I sold the truck before I ever got to run it.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Ninja Engine by GRP ogreasurada Offroad Nitro Engine Forum 1526 09-16-2013 07:13 PM
OS 18TM help needed badly. jairic Monster Trucks 56 06-04-2008 08:07 AM
wts used os rg .21 motor will g R/C Items: For Sale/Trade 13 05-08-2007 11:28 PM
Stephen Bess break in method Ryu Goh Electric Off-Road 7 04-06-2006 11:45 PM
maxx bowties and wheels a/efreak R/C Items: For Sale/Trade 26 10-07-2005 09:12 PM
SEO by vBSEO 3.5.0
