NEW NOVAROSSI 2009 ENGINES
#226
What's the bearing size for Nova Flash Tuned?
#230
I wonder what kind of plugs the teamdrivers are using/getting, as a factory you do not want to have such issues loosing important races. I can imagine there are better plugs available for the teamdrivers.
#231
#232
Is there anything that playing with the midrange needle can do to help this? Also, is there a default setting for this needle? I couldn't find it in the novarossi carb manual.
Also - for the sirio plugs, what's the equivalent to a C6-TGF in sirio?
#234
Hi. Wich odonnell plug to use in Novarossi flash (odo99T) ?
#235
Is the heat sink of the Flash Tuned got extra holes for cooling and lighten, like the pic on Nova site? coz mine doesn't have any...
#236
#237
We had a strange issue with a new Flash as well 09 production, sealed from the factory.
Did our usual thing prior to run in, stripped it to make sure it was clean inside etc (which it was), it felt a bit tight but we assumed it was just the layup oil.
Noticed it had been run from the factory, some light scuff marks on the back plate, strange but we continued on.
On re assembly the engine felt tight, stripped it again and then put it back together again and it was fine. Never, ever had this before with a engine....
Engine was then run in, and it's been used for a race meeting with no real issues.
I guess time will tell if it's going to go wooshca...
Regards
Kyle
Regards
Kyle
#238
tino why are you always asking about LAY-UP OIL
#240
