NEW NOVAROSSI 2009 ENGINES
#137
#139
The advise is to keep it flush to the housing.
#140
All I will say is, this is what I use: http://cefx.net/catalog/breakin.php Just so you know, you will have a decent amount of pinch left doing this method. I also had an engine expert look at my motor after break-in and he said whatever method I used is a good one because the motor looked like it had been broken in right, in his opinion and he didn't know what method I used. This method seems to be pretty popular and I haven't heard anyone say that they didn't like it. Doesn't mean someone out there doesn't though...
If you want hardly any pinch left after break-in, use Mike Swauger's method. He posted it on rctech somewhere and I used it on my plus 12 and that motor has been really good to me. But, I think it's getting worn out a little too fast and it might need a piston/sleeve soon. Hope that helps.
Paul
#141
Thanks Roelof for the input.
NOW who knows if it is fairly safe to NOT use any type of air filter breaking in an engine on the Hudy Break-in Bench? The manual says an air filter is not used on their Break-in Bench. Plus there is no room for it installed on the engine.
http://www.hudy.net/xhudy/products/p...89&kategoria=0
#143
Hey Jason...no air filter I'll try that...how is R.A.M.S these days?
What happened to the MRX4X?
Are you running the Evolva M3 nowadays?
I just built my M3 a few weeks ago...and it is very similar to my old Mugen...just picked up a Flash .21, gonna break that in this weekend (hopefully)
Hope to get back to R.A.M.S. again soon (too much work here in S.F.)
Take it easy~
Take it easy~
#144
You can use a smal piece of clothing mounted with a tirewrap directly on the carb and oiled a bit.
#146
#147
sorry...double entries...
#148
Thanks mate...at least you'd provide me with the extra info that i'm after here...
#149
For a filter on a break-in bench, just take the foam off the rubber base of one of your filters and tie wrap it onto the carb. No worries about dirt getting in.
#150
I ended up going with the 353 09 so I am very interested in the pipe question also. I am currently using the 2630 with great results but I am interested what is noted as best for the 09. I will be trying the 2620 also along with the 2601 as these are the 2 I am thinking to get otherwise I will just get another 2630.
