OS .21 Vspec II World Edition
I just saw this engine. What do you guys think about Hara's engine?
http://www.rc-toro.com/product_info....208d1ee009fe32
anyone, plz??
The engine should be just like the previous Speeds. Not sure the exact internal changes from the MAG or AL versions if any, but I believe we have one or two at our track and it seems to run just as good as the previous models. Changes on paper are the lightned head and reducers supplied. Comes with 6mm, 6.5mm & 7mm now compared to 7mm, 8mm, & 9mm on the previous models.
I finally came up with the money to buy Vspec II. Yes, it is expensive ($400+), but I think it is worth the every pennies. I had it for about 3 wks, and I actually saw my lap times improved!!! Compared to my old Go engine, this engine actually has a MID-BAND. Much smoother, and much easier to drive. Go pretty much is on and off, regardless of how I tuned it. VspecII gives you a much bigger power band to play with. This I think translates to much better corner speed, and at the end much better result.
hara's motor
