Picco P9 EVO3 .21 Race Engine
#31
ok guys, my EVO3 is installed on my 960 (without the lcg monoblock, cause I need to dremel it a bit)
But which pipe does this engine loves most?
The 2033?
or does the 2052 also works really well, like it did on the Mega DSII, and Picco EVO2.....
The 2033?
#32
I also want to know which pipe this engine performces good with
#34
We are not allowed to race the 2013 anymore under EFRA...
To much noise....
To much noise....
#35
how is ofna and picco making these engines at an extremely competitive price, having them perform better or equal to $400 italian mills, and the "other" brands still are instant on charging $500 for their engines.
take the JLR Red-Dot for example $180 engine, goobs of power, VERY close to Novarossis in performance, close to half of the cost.
the Picco P-9 Evo 2, $279, great budget engine. tons of power, also very cheap compared to the other engines.
I know novarossis and other italian brands are great engines, i own 2 of them.
but when brands like picco and ofna are catching up so quickly, should they drop their prices to stay competitive? or will people just keep buying the novarossi brand at what ever price because of their reputation?
the picco p9 evo 2 was impressive, and lets hope the evo 3 is the same, but I DO love the art on the cooling head, I would cry my eyes out if I had one and I flipped over scratching it...
#36
OFNA is not making any engines, PICCO is.
Why people still buy these very expensive mills?... I really don't know, but yes it has a lot to do with reputation and some people still believe that if it is expensive it is fast.
To be honest, I also think that a Nova is a bit faster, but certainly not worth the double price....
$279 for the EVO2 you said?,
I bought my EVO3 for $277...
http://www.mijnalbum.nl/GroteFoto-QGR6H48D.jpg
#37
what is your opinion?
#38
Yes I did/do, still have 2 Mega DSII and 1 DSII+ engines, and still am using them, 1 of them will retire soon, because I ran 4 gallons through it, which is the max I will use an engine.
I can't tell you the performance difference, because the Picco evo3 still needs to break in, together with my just ordered IDM evo3, which is on it's way....
But looking at the internals they are very similar, so probably will perform very similar....
Serpent will come with there new DSIII line, and if they where sooner, I would have bought them, now they are just to late for me.....
#39
something last,have you noticed any crank wear in these engines?this with 4 gallons?
#40
I have ran the JLR .12 red-dot and novarossi engines.
the only difference I see in those engines is that the novarossi was a PITA to break i with my weak starterbox while the picco was easier.
after break in I noticed no difference.
I have a N21B buy novaorrsi in my hyper 8.5 pro, might be a weak engine, but its been modifed to squeeze out more power, I havent broken in the damn motor because its soo tight, and my dual 550 motor box can't turn it over.
#41
But, No, no visible crank wear.
I really abused this engine, to see how far I could go...
leaned it, up to 148 celsius (300 fahrenheit) and at the end of the straight, it started complaining , but didn't die...
Only don't use Picco glowplugs, but instead, go with GRP or IDM/Sirio (IDM plugs are Sirio based)
Also 1 conrod has been used more then 10 liters (2.5 gallon) and after replacing it, there still was no real difference noticable in play between the old and new conrod.
Normally I don't recommend using any conrod in any top-end engine for more then 10 liters, because of the stretch exersizes a conrod goes through, it gets tired....
But in this case it was to test the durability...
Also even if you pre heat the engine?
#43
Always pre-heat engines before break in.
Actually I always pre-heat my engines before starting them at race days also after break-in, but we in the Netherlands have very good facilities, with power sockets available at the pit table....
#45
yep, then you need a bigger starter box....
