khm evo6 info needed
I am looking for a base line carb setting and overall impression of this motor, I got it with my 960 and it was freshly broken in. I am having a difficult time tuning. I have it decent, but not quite there. Also what pipe do you reccomend for it. And where should i shim the head for 30% nitro?
Also I have a stock p9r, would that be a faster motor? |
The EVO6 is a Novarossi product as also the JP and R&B engines from who I know they published base settings.
www.jpracing.com www.rbproducts.com The right pipe, the 2052 is a well performing pipe on all Nova based engines but consuming.... The 2015 does give almost the same performance but better consuming. The Sirio 2013 is an awesome pipe for long runtimes, it will give less top RPM but lots of torque you can compromise with other gears. |
I can find some general baseline settings, but noting specific, the jp sight has specific info, but I can't figure out which one would pertain to my motor.
thanks, that should get me there.
