Max 21 XL9
Old 05-16-2008, 05:43 PM
Default Max 21 XL9
does any one Know the part number for a piston and sleeve for this motor?
thx
Lou
look is offline
Old 05-16-2008, 05:51 PM
MugenDrew's Avatar
Trader Rating: 36 (100%+)
MX 08551 XL9 < that's the part number. Piston/sleeve/rod/ and I believe wristpin and clips.
MugenDrew is offline
Old 05-16-2008, 10:19 PM
XL9 MF PISTON SLEEVE+CONROD SET
It comes with head buton as well. I believe you can only get the MF (matched) version and is around 300+ USD a set.
twoo is offline
Old 05-18-2008, 08:09 AM
is this the same piston and sleeve as the 35 plus?
Lou
look is offline
Old 05-18-2008, 08:35 PM
It is based on the 35Plus engine... have not measured the port height to see if they are the same. It took months to order the Max P/L set though...
twoo is offline
