over lean when no fuel...
hi all,
as you know that when yr nitro gonna finish up, u'll reach the stage that it'll be 'over-lean'; any ways to prevent that?
i've had several plugs burnt out due to this... it happens just when yr tank runs dry.
It seems the engine is setted critical, a tiny bit richer or one degree colder plug can work to keep the plug alive.
But yes, it is a known issue the plug can be damaged with an empty going tank.
what's the optimium length of pressure line? does pressure chamber really help?
