picco 28 factory needle settings?
Hello all,
I'm new to nitro, and bought a trinity 28, which is the same as picco... it came without any paperwork, and i'm wondering what needle settings to use to start break-in. Thanks for the help!
I guess this engine uses the same carburator of P7R-Evo2 off road
so the needle settings are
Master Needle 5 to 51/2 turns from closed
Low speed, needle out of ball end (rich side) in (lean side)
Idle 1/16th inch open
all according to instruction sheet
The engine comes with a default setting which must be a situation to fire it up.
Tiny adjustments may be needed to the idle screw en when started just find the right rich setting on the HSN for running in.
Thanks for the help. I'll start from there.
