Engine Mod'r List
#46
but not independently..you can raise or lower the sleeve to alter timing.... but thats not the same as altering ports independently...
#47
Maximo, I can do it independently for each port individualy-
I just suggested to read my signature, you don't want to listen me.
If I say I know-that means I know.
Edward
Edward
#50
#51
Btw, Edward, I still got that aluminum P/S set!
Edward, what#s your opinion on measuring the crank window with a caliper?
I tired that in the past and it never really worked, so i went back to the tedious way, using the degree wheel.....
#52
Trust me, he can. He's done it to one of the piston / sleeve sets I got from Edward a few years back, and it was a work of art.
but I have alot of respect for Edward, he offered me very good advice when i started modding engines... So I will gladly give Edward the opportunity to prove me wrong...So I will bite on this loaded topic and call B.S. on altering a sleeves timing without altering the ports....As in independently raising the boost port timing without affecting any other port..... I know myself it takes many hours of elbow grease to properly alter a sleeves timing, if there is some magical new way to do so please fill me in.......... Using diamond files takes far too long !!!
#53
#54
Maybe Edward will choose to tell you how it's done. It's not my place to give his knowledge to others.
It's actually not hard to do if you think about it
It was an elegant way to change exhaust timing when we still had the 4.5mm rule...
he can adjust a port timing without touching the sleeve... as in add 6 degrees of boost without altering any other port...actually by not touching the sleeve at all ??? maybe when pigs fly !!!!! of course i guess Edward could create a whole new sleeve with new port timing, which would alter sleeve timing without touching the original sleeve...LOL !!!
#55
i can think about it..i mean I alter timing on these engines every day..... I mean either you raise the port or you raise the sleeve..... you can shorten the rod but that affects all ports, not just exhaust, just like raising the sleeve.....
Say a particular motor had 126 degrees of transfer timing and 118 degrees of boost timing, and 168 degrees of exhaust timing......... Myself I would look to raise the exhaust to 180 degrees, and raise the boost from 118-126 degrees...... so I am adding 12 degrees duration tothe exhaust and 8 degrees duration to the boost............. The only way to do this is to cut the sleeve ports... if anyone has any other way to alter the timing as I have previously stated please let me know........These are only hypothetical numbers of course......
#56
Shortening the rod is great idea. Putting it back together is where the problem lies...
#57
#58
different piston hieghts definately alter the port timings, it also creates turbulance and if done right, can improve flow. there are many tricks to these engines, thats for sure, my time on performance 2 stroke bike engines has made me aware of the similarities to these small powerfull engines. just next time dont rule out something thats not knowledge to you.
if you want to see how your engines perform, get one to a capable driver in a big race, then you will see how your motors compare. there is nothing like a nationals or worlds event to bring out a heap of 'special' motors to factory drivers.
#59
#60
never say it cant be done. 2 stroke piston is your valve for a 4 stroke.
I had 6 of my motors running at the Canadian Winter Nationals last weekend...2nd year in a row !!!!! clearly and honestly we had the fastest, most efficient motors on the track..........this is my second year at the Canadian Nationals as well.... in offroad my motors have no equal !!!!!
I knew edward had a trick up his sleeve, but i figured i'd take the bait and and let him prove me wrong.....
I cannot see being able to alter much timing by cutting the piston top...definitely not the same as cutting the actual port... my C6 needed 16 degrees of exhaust timing cut, which is massive !!!!!
