Tune pipe questions
Old 02-24-2008, 07:47 PM
Trader Rating: 15 (94%+)
Default Tune pipe questions
Hi guys
I just wanted to clear some things up..
is a long pipe considered a torque pipe?
meaning i run taller gears for more top end?
mrgsr is offline
Old 02-24-2008, 08:18 PM
Trader Rating: 28 (100%+)
Originally Posted by mrgsr
Hi guys
Yes, longer gives more torque, shorter gives more rpm. Manifolds are a better way to change lengths.
Scott Fisher is offline
Old 02-24-2008, 08:20 PM
Scott i used to run the mugen efra 2501 pipe with my picco evo 3 now ive put on the picco 2607 and the pipe is about 20mm longer so the torque should be more
mrgsr is offline
Old 02-24-2008, 10:26 PM
stefan's Avatar
The two pipes you got there are the two absolute extremes:
2501 is THE rpm pipe
2607 is THE torque pipe
The difference should be night and day.
stefan is offline
Old 03-01-2008, 08:23 PM
keavze's Avatar
so...with rpm pipe should run shorter gears and torque pipe running taller gears?
in addition: a high rev engine shld use a torque pipe and vise versa?
keavze is offline
Old 03-02-2008, 03:28 AM
all depends really i've used a 5 fin nova header with a nova 2630 on a max, and it was ok, but the crf pipe with long header felt better. some engines like weird combos you wouldn't normally consider. sometimes it pays to play around.
TomB is offline
