Picco P9R problem
Picco P9R problem
My P9R has a problem
Sometimes when I turn right the engine richen a lot.. it does alone ..
Low speed is not rich. When the car is in the bench works very good but in the track not
right turn would put an overly full tanks fuel into the pressure line, common after refills to richen up because of this.
I'm sure you know this, but the bench tune is most likely too lean once you put a load on the motor on the track.
