Old 09-09-2007, 06:44 AM   #1
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Default Deck clearance/head shim size on Kyosho .28
I just picked up a Kyosho Inferno GT. The track by me has a spec class for these, and we run the stock .28 that comes in the kit. It's a basic RTR engine, but a fun class with all of us on the same page
Prior to any fuel, I always disassemble my engines to seal the carb and backplate. While doing this, I'm pretty sure I lost a head shim.
Before pulling it apart, I measured the deck height at .025" - it's .017" now.
Either way, what do you guys suggest as a deck height for 30% fuel?
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5b SS 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 09-22-2007, 03:14 PM   #2
Check out what your manufacture says. I run .90 to 1.0 when running 30%. Remember you are lowering compression the more shims you run. Your bottom will be less and your top will be more.
Most manufactureres shim their heads up to 25%. Some are stock for 30% check your manual.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
GHETTOTEACHER is offline   Reply With Quote
Head Shim nsgland Electric Off-Road 1 12-18-2007 01:54 AM
Shim Size. Michael Barch Electric On-Road 2 02-10-2006 07:09 AM
.26 Head Shim SIRMAXXALOT R/C Items: Wanted to Buy 1 05-06-2005 11:36 PM
Head shim Question. ?? Ybakoff Onroad Nitro Engine Zone 2 04-11-2004 03:25 PM
vones gsr 15 head shim geoffrey Nitro On-Road 2 03-08-2003 01:08 AM
SEO by vBSEO 3.5.0
