Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Is Hobbico After Run Oil good? >
Old 06-04-2012, 05:59 AM
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Default Is Hobbico After Run Oil good?
Just curious if it's safe on the newer motors since it's the only ARO available at my local store.
ToysRUsKid is offline
Old 06-04-2012, 06:21 AM
choisan's Avatar
My Mobil1 never fails
choisan is offline
Old 06-04-2012, 06:54 AM
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i use a 50/50 mix. mobil 1 and syn trans oil . works a treat. if you can buy a liter of mobil one, and 500ml of syn trans oil, pour half the mobil one in your real car (it will love you for a few days) and pour the trans oil in. one liter of after run lasts for ever.
Pattojnr is offline
Old 06-04-2012, 04:12 PM
bigredspeed's Avatar
Tornado after run is the best one on the market!!
bigredspeed is offline
Old 06-04-2012, 04:23 PM
tonylunatic's Avatar
Trader Rating: 45 (100%+)
I think any kind of decent oil mix or after run oil is recommended, to nothing at all.
Btw, I'm trying Marvel Mystery oil, it works awesome on bearings
, air tools for moisture and your real car engine!!
tonylunatic is offline
Old 06-04-2012, 05:26 PM
*1speedy's Avatar
What’s up Tony
I used the mystery oil for years It works very well then 1 day I was talking to Eric Selesky / AKA Big E Selesky the Owner operator of Nitro Dynamics out in Cali. God rest his soul.
His Drag Engines were off the hook !!! For some reason we were discussing what lubrication he was using in his modded engines.
He told me about CorrisionX and I have never looked back. I have never had any issue with it and the “film” it puts down doesn’t just run off with gravity I was very impressed with its properties.
Here is a link to the home page, read for yourself it’s incredible. Heavy Marine and Gun users swear by it.
I use the Red can 6oz spray.
http://www.corrosionx.net/corrosionx.html
*1speedy is offline
Old 06-12-2012, 06:54 AM
blanks596's Avatar
Trader Rating: 20 (100%+)
yes, hobbico after run oil is fine. Been using it for the past 6 years with no problems
blanks596 is offline
Old 07-06-2012, 01:30 PM
adrictan's Avatar
Originally Posted by *1speedy
What’s up Tony
It's the aerosol version of CorrosionX. Can I use the Trigger Spray type?
adrictan is offline
Old 07-06-2012, 05:00 PM
asw7576's Avatar
60:40 mixed, 60pct of mugen seiki or novarossi maintenance oil, 40pct of mobil one 5-50 full synthetic oil. Awesome.
asw7576 is offline
Old 07-06-2012, 07:12 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
Al most of the red AROs are is ATF. So if you like it, go get a bottle of ATF from the auto parts store.
Marvel Mystery Oil is just ATF with oil of wintergreen added.
ATF is a good ARO. The only problem is that they say it can damage the silicone ramps in many cranks these days. I have never seen it, I suspect you would have to soak it in ATF for months to have a problem. Still, just to be safe I switched to a synthetic oil. Mobil One is doing just fine for me.
wingracer is offline
Old 07-06-2012, 08:20 PM
we have been using just singer sewing machine $2 at woolworths get it on mums bill
greg
greg.dawn is offline
Old 07-06-2012, 08:49 PM
asw7576's Avatar
greg
no, dont use singer oil, the silicone putty inside crankshaft and o-rings inside carburators will be swollen. Singer oil is not meant for rc engine.
asw7576 is offline
Old 07-07-2012, 05:50 PM
blis's Avatar
Default Oils aint Oils Sol'...
Whatever you choose to use, consider how it will react with your racing fuel.
Scrub alu or steel clean of oxides, place two drops of fuel on cleaned surface, add two drops of AR oil, one on fuel and one on metal. Leave for a day or so, check if there are reactions between fuel and oil creating coagulates and see if oxide forms on metal.
blis is offline
Old 07-07-2012, 06:01 PM
*1speedy's Avatar
I am sure they are the same
This is one of the best products I have bought for any type of lubrication needs
*1speedy is offline
Old 07-07-2012, 07:29 PM
Tim Johnson's Avatar
The packaged Hobbico oil is repackaged Marvel Mystery Oil.
So yes, it is good, And really the best way to clean, de-gum or store your r/c engine. It is designed to be burn, so if you have any left in the engine, it will burn away, unlike motor oils.
Tim Johnson is offline
