Old 07-28-2007, 07:53 PM   #1441
Head on over to your local motorcyle shop and buy a lifetime supply (one whole pint) of Belray air filter oil - think I've had the same bottle for 15 years - it will thicken up, just rethin with naptha.
Rick Davis is offline   Reply With Quote
Old 07-28-2007, 08:41 PM   #1442
J.Wright's Avatar
Yeah I been using the stuff from K&N but not I am out and need to change air filter oil in my K&N on my truck, man is that stuff expensive.
Jim
J.Wright is offline   Reply With Quote
Old 07-29-2007, 09:23 PM   #1443
Goingfast's Avatar
Trader Rating: 29 (100%+)
What is the high and low needle Pre setting for .12 LL3 murnan modified motor...
what plug number do they recommened?
Goingfast is offline   Reply With Quote
Old 07-30-2007, 07:56 AM   #1444
Bob Malphurs's Avatar
I've been using the same pint bottle of K&N for about 15 years! Probably have enough left for another 10!
Bob Malphurs is offline   Reply With Quote
Old 07-31-2007, 07:29 AM   #1445
Much Much More's Avatar
I just received my Murnan Modified RB R3 and I will be running 25% Tornado fuel. Must I add a 0.1mm shim or to run it stock? From what I know, the engine seems to be built to run on 16% fuel.
Much Much More is offline   Reply With Quote
Old 07-31-2007, 07:44 AM   #1446
ziggy12345's Avatar
Grinder. Here is the vid of the run at the California Speedway
http://www.youtube.com/watch?v=tJPcL...related&search
I jumped off the wall and unplugged the lead from the TX. I was just linig up for another run
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-31-2007, 08:47 AM   #1447
JetMD's Avatar
Uriah, YGPM.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 08-05-2007, 03:00 AM   #1448
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Uriah,
Ran the motor that i brought off you at our state titles this weekend along with one other and just thought you would like to know that we both finished in the top 10. Your motors are brilliant and it just seems to be getting faster and faster, cant wait to run the other one.
Daniel
Slo-MTX4 is offline   Reply With Quote
Old 08-05-2007, 09:26 PM   #1449
SlamMan's Avatar
I just picked up the modified RB R3. Will I need to shim it to run it with 30% Werks fuel? Any suggestions for which plug to run?
SlamMan is offline   Reply With Quote
Old 08-06-2007, 12:59 PM   #1450
chicky03's Avatar
Send a message via AIM to chicky03
Thanks for the great motor work and support at the GLC. I was extremely happy with the work you did and help I recieved.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 08-12-2007, 08:33 PM   #1451
robert maestrey's Avatar
Uriah thank you for such a great powerplant
I was very happy with my package this weekend allowing me to set TQ in sedan and lead race until the last three minute mark when I had a commanding lead and came in for a splash, unfortunately I flamed out my fault and causing me to loose the lead...oh well that's racing and it doesn't take away from the fact that there isn't anything Id rather be doing than racing Congrats to all the winners especially to Maxy for a great return to Touring hope you come out to more races
Port Charlotte puts on a great show and I highly recommend for anyone that can make it out you will not be disappointed David Larry, Gary Tuttle and all your help congratz great job.
Thank you to all my sponsors: Kyosho America,Werks Fuels
Murnan Modified Motors, Pnp Hobbies
2mm Designs
http://www.rc-racing.org/pc.html
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 08-13-2007, 04:59 PM   #1452
Hi Grinder
I have a matrix munrnan mod., when do you suggest I should change the main bearing? I've race it only once and it already making a noise like the main bearing is bad. It was fast as hell, it never went more than 215F.
Thanks for your time.
El Buenote is offline   Reply With Quote
Old 08-16-2007, 06:52 AM   #1453
Grinder's Avatar
Originally Posted by El Buenote View Post
Hi Grinder
You can send the engine in for me to check. The bearings should last longer than that. Is the top of the piston pitted?
Grinder is offline   Reply With Quote
Old 08-16-2007, 06:54 AM   #1454
Grinder's Avatar
The LL3 engine should start with 4.5 turns out on the bottom needle, and flush on the top needle, usually about 6 turns out.
Old 08-16-2007, 06:55 AM   #1455
Grinder's Avatar
You should add .3mm of shims to the engine for 25%.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
