Old 06-04-2007, 05:52 PM   #1366
Grinder's Avatar
Originally Posted by dg8one View Post
hey Grinder
do i need to shim my motor or not?
i'm using 25% Tornado Fuel
when r u arrived?
thanks
nelly
You are already shimmed correctly. We will arrive Wednesday afternoon sometime.
Grinder is offline   Reply With Quote
Old 06-04-2007, 06:55 PM   #1367
JL POWER
Hey Grinder
The Rookie is offline   Reply With Quote
Old 06-04-2007, 06:57 PM   #1368
Default JL POWER
Hey Grinder is the mega 2607 agood pipe for the JL Red Dot?
Old 06-04-2007, 09:06 PM   #1369
Trader Rating: 281 (100%+)
Uriah,
I have one of your 35plus21 engines. It cuts off at the end of the straight. using #7 plug, 20% Byron's fuel, engine temp between 240 and 260. Do you know what the problem is? I race at 301 in MD. Any help will be appreciated.
rcdoktor2 is offline   Reply With Quote
Old 06-04-2007, 09:29 PM   #1370
dg8one's Avatar
thanks Grinder
i'll see u guys wed i'll be their at noon taking care of the wife so she wont bug me out the rest of the week
thanks again
nelly
dg8one is offline   Reply With Quote
Old 06-04-2007, 09:31 PM   #1371
dg8one's Avatar
Originally Posted by rcdoktor2 View Post
Uriah,
20%...... i still have a gallon of 104 octane lmk if you want me to bring it
Old 06-04-2007, 09:35 PM   #1372
theRED5's Avatar
R/C Tech Charter Subscriber
Hey Uriah, Good Luck to you and the rest of the Atlanta crew at 301 this week.
Sounds like you have the armement to blow the competition away.
theRED5 is offline   Reply With Quote
Old 06-08-2007, 10:02 PM   #1373
RcDoctor, check your two speed.... i had the same problem this past weekend, then i checked my two speed and it was shifting too early which caused the motor to wind out too much. try tightening down the two speed a little.
sikbrahmugen317 is offline   Reply With Quote
Old 06-10-2007, 02:15 PM   #1374
ziggy12345's Avatar
Uriah,
When an engine cuts at revs its because the head is too low. As the revs in the crank increase so does the pressure in the head and advances the timing. If its already too advanced it stops it dead.
Add 0.2 head shim will cure it
ziggy12345 is offline   Reply With Quote
Old 06-17-2007, 09:41 PM   #1375
Default 301
So what did you use for the 1/8 finals. How did the mod 359 go? I am thinking getting either 359 or Xenon R.
Hi. Personally I will be testing another prototype modified version of the Novarossi 359. I will also be running the RB XenonR in my Evolva. We will be testing a modified version of the NS21P, which stock is a pretty fast engine. This is the engine that comes with the 359. I may also try the 3 needle carberetor that comes with the NS21P on the 359. Oh, and of course there will be the modified 35+21's
For sedan I will be testing the modified RB Matrix, and the Novarossi 353 modified. My team will be testing the stock practice engine that comes with the 353, the modified Picco Drake, modified Ninja .12's, mod +12's. The Ninja T01 modified is a good engine. Gobs of top speed. We will be playing around with dropping the head on the Ninja .12 at the classic to see if more torque can be found.
It should be a fun, and busy week! Only 3 more days to go.
slide_228 is offline   Reply With Quote
Old 06-18-2007, 05:34 AM   #1376
ziggy12345's Avatar
WOW That RB Xenon motor is fast! I have the bog standard version and its awsome! I have it in my fast car
http://ziggy12345-myspeedattemptcar.blogspot.com/
I have a sirio and a JP in the car as well, I think i'll ditch the sirio and JP and get 2 more RBs
Cheers
Old 06-18-2007, 06:11 AM   #1377
Grinder's Avatar
Cheers
Very cool project. Let me know if I can be of any assistance to you. Has the car shifted into second gear yet? I wonder how you can control all of the engines rpm, and shiftpoints exactly? What happens if one shifts, and the others do not? Just wondering. I imaging special gears would have to be made to hit 150mph. Keep up the good work. Please keep us posted here too. I wonder if anyone has ever tried a twin engine on road car, let alone a 3 engine.
Old 06-18-2007, 06:23 AM   #1378
Grinder's Avatar
Hi. unfortunately I did not make it to the final in 1/8th. I qualified in the B main in the 8th scale, I finished 14 overall in 8th scale. I tested the RB XenonR, and the 359. Both modified versions. My friend Frank Sossebee blew his engine, so I let him test the 359 for his main, so I ran the XenonR. The XenonR was very fast all week, as well as the 359. I had a bad crash with the XenonR the night before the mains, so my car was no good, but the engine was great! The modified 359 ran very consistently all week. The modified 359 has more torque than the stock version with very good top speed. I am very happy with the modified 359. We also tested the modified NS21P that comes with the 359. The engine was suprisingly powerfull. Jamie Corrado was on an A main pace with the engine when something happened, and he did not make it. The engine is extremely torquey, and lacks the top speed of the more exotic engines. It is a very good club practice engine. The modified 359 gave Frank Sosebee the fastest laptimes of the week. He was using the modified 35+21. Maybe we can hear about the feeling of the engine from him sometime soon. hehe.
Old 06-18-2007, 06:43 AM   #1379
ziggy12345's Avatar
Hi
Thanks for the support. I have only got the car rolling around outside the house and a blip of the throttle destroyed the plastic pulleys and middle belts!
I have ordered steel re enforced belts 5mm pitch that can take 74lbs load and aluminium pulleys.
The gearing on the car will remain the same but the gearing from the layshaft will be changed from 20-48T to 32-32t to give 1/1 drive to the rear axle.
For the 2 speeds I think it will happen like this.
As the first engine shifts in to 2nd gear the car will accelerate and the other engines will pick up speed rotating the layshaft faster and kicking in the other 2 speeds. If the are set anywhere near close they will all change so fast you wont notice it. (Thats the theory!)
The problem is the clutches. Normally a 1/8th car engages the clutch and it slips until the car pick up speed which is only a fraction of a second. On mine this will be a long time so I am expecting a lot of slip.
I will add 3 small grub screws to each weight to increase the clutch engage pressure but this will kick in the clutch really early so might stall the engines. I need to find the right balance
Grinder! Send me a sticker for the side of the car!!
Old 06-18-2007, 01:43 PM   #1380
hey grinder, do you have any comments on the ns12p?
randay is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
SEO by vBSEO 3.5.0
