Old 03-07-2007, 08:18 PM   #1171
afm
afm's Avatar
Originally Posted by Fabian K
AFM,
I see you know everything thanks about explanations
I will find the pictures that i have for my SPEC 3 inside and post here or LRP section(engine forum) , whatever you want
I know for sure that SPEC 3 is better (botton end, mid and high end power) than SPEC 2 I race LRP engines since the spec 1
the differences that i see lrp spec 2 to spec 3 are;
the top of the sleeve is longer ,to compensate, the burning room is also longer (inside ) to maintain same clearence- same head shims
the cranckshaft has black anodized on some parts with minor modifications
I do not know about timing if had changed
the conrod has two small risks on inside botton side like megas
the coolong head is little diferent
and back plate also
Maybe i forgot something but......
Fabian
It's Ok Fabian, since i have RC Shop and distribution of several brands I have to be informed of everything, and I have good sources..jejejeje
I've had Picco engines since the old side exhaust and currently I have a JL Red Dot and a Picco Evo2 Edo Tuned, so I know a bit there and here about Picco engines...jejejeje...they are crazy fast.
From what you describe of the LRP Spec3 it seems to have same parts as above engines I have.... maybe difference is in timings and silicone ramp on cranks of engines I have, also my Edo has backplate with dished-in recess aligned with discharge exit of crank hole, also the crank bore is bigger than the one on the JL.
Please do post pictures on LRP forum, I don't want to abuse on Murnan's thread, which is meant to talk about his engines.
On a side note. We're having a big race here in Peru on April, with guys from Chile, Ecuador, Colombia......If you are interested in coming send me a PM and I'll fill you in with details.
AFM
afm is offline   Reply With Quote
Old 03-08-2007, 04:41 AM   #1172
Grinder's Avatar
Default New Engines
The Modified JLR Red Dot is in stock, as well as the modified Ninja T01A. We also have the stock version of each engine if you are scared. Ninja pipes are here too.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-08-2007, 12:55 PM   #1173
Diesel Racer's Avatar
Has anyone run Byron fuel with the Murnan Modified CRF, according to Nano in the CRF engine thread it's not the best fuel for performance, but my choices are limited, my only other option to Byron is Weston ProSynth which is readily available.
Any feedback would be greatly appreciated.
Mark
Diesel Racer is offline   Reply With Quote
Old 03-08-2007, 01:05 PM   #1174
impalabob64's Avatar
Send a message via AIM to impalabob64
Default DRacer
I tried Byrons motor didnt seem to like it,i run Toro Fuel now, motor loves it runs about 10 to 15 degrees cooler.Just my 2cents
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 03-09-2007, 08:28 AM   #1175
Grinder's Avatar
Default New Engines in stock
Old 03-09-2007, 10:40 AM   #1176
impalabob64,
Thanks for the feedback, I've always run Tornado but can't get it for love nor money locally now and the shipping costs are almost as much as the fuel.
The local model shop only sell Model Technics, not sure what there new Sical blend is like, I know I can get Weston ProSynth a short drive away but never had any experience with their fuel which leaves me in a dilemma, your experience with Byron backs up Nano's view.
Regards, Mark
Old 03-09-2007, 02:13 PM   #1177
duneland's Avatar
Default fantini
Hi uriah I have a new in box fantini .21.
I am going to use it for drag racing.
Is there any improvements you can make to this engine if I send it to you?
What would you recommend be done to it?
How much and how long would it take?
duneland is offline   Reply With Quote
Old 03-09-2007, 04:10 PM   #1178
quietstorm76's Avatar
I run Bryon's in my Murnan. It's good fuel, very safe but I've ran other fuels that make more power. I chose to run Byrons because I can get it any time I need it.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 03-09-2007, 11:27 PM   #1179
Thanks for the info quietstorm76, I assume that Byron's has a slightly higher oil content to say Tornado?
Mark
Old 03-10-2007, 06:10 AM   #1180
mugendude's Avatar
mr bobby watson your rev is the fastest thing on the track
murnan modified rb xenon R ballistic missle i love the smell of nitro in the morning
www.rc-racing.org
mugendude is offline   Reply With Quote
Old 03-10-2007, 07:13 AM   #1181
No problem diesel
Primary Weapon: ?
Secondary Weapon: ?
Old 03-10-2007, 09:21 AM   #1182
Grinder's Avatar
Default Ninja Review
Ninja .12 Review is up on the website.
Old 03-10-2007, 09:46 AM   #1183
rmdhawaii's Avatar
Thanks for the review.
- How does the Ninja pipe compare to the Skyline pipe?
- Is your conventional break-in similar to what Mike S. is doing? If not, what are you doing different?
Thanks Uriah!
Originally Posted by Mike_Swauger
1st Tank at idle. Shut it off and let it cool down. Make sure the piston is at the bottom.
2nd tank idle
3rd tank 1/4 throttle
4th tank 1/4 throttle
5th tank 1/2 throttle
6th tank 1/2 throttle
7th tank 1/2 throttle
8th tank full throttle (make sure engine is running rich)
9th tank 1/2 throttle
10th tank 1/4 throttle
Put the engine in the car and run two or three tanks at a rich setting on the track and then it will be o.k to lean it out.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-11-2007, 07:25 AM   #1184
Grinder's Avatar
Thanks Uriah!
Hi. I will try the Skyline pipe today. I used the similar break in to the one Mike posted. Works fine for me. Well time to go pound the Ninja's at the track. Stay tuned for a report!
Old 03-11-2007, 12:10 PM   #1185
I just ordered one thanks mr murnan! hope it comes with some stickers so people can know whos motor is smoking them down the back straight
randay is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
