Old 03-05-2007, 08:36 PM   #1156
robert maestrey's Avatar
big thank you to Uriah Murnan for a ballistic Motor this weekend...you are the man....didnt finish as high as I would have liked, but I had fun
Jeff the food was off the chain
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 03-06-2007, 07:28 AM   #1157
Big Jeff BBQ's Avatar
Thank you Robert !
Glad you enjoyed it !
It was a great weekend of racing.
see ya soon
Jeff Epperson
Blowin' Smoke BBQ
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 03-06-2007, 12:49 PM   #1158
Grinder's Avatar
Originally Posted by buboy28
hi, Uriah,
do you do modification work for the Ninja buggy engine, thanks
Yes.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-06-2007, 12:51 PM   #1159
Grinder's Avatar
Originally Posted by cdelong
Uriah,
On a stock 35Plus21 what should the head clearance be set at running 30%?
Out of the box it was 0.022". I run 30% and usually set my clearance to 0.028" on my 321P's. I just wondered if maybe the combustion chamber was larger on the 35Plus21 and hence why it is at 0.022" out of the box with 0.7mm of shims.
Should I add a 0.1mm shim to bring it up to 0.028"?
I suggest you add the the .10, or .15mm shim to run 30%. That is somewhere around .80-.85mm total shims. Also depends on the weather some.
Old 03-06-2007, 12:55 PM   #1160
Grinder's Avatar
Originally Posted by impalabob64
Hey ,Bobby watson here ,great news from Kraceway the MMCRF ,performed this weekend, put me second starting position in the B-final behind the Boss Uriah.Won the B-main,bumped to the A-main finished 8th position.25min B-main ,30min Amain.
Great Job Bobby, but you beat the boss.
Just Kidding, your car was flying around the track. You da man!
Old 03-06-2007, 12:58 PM   #1161
Grinder's Avatar
Originally Posted by shocker360
Hi Uriah,
Due to the success of the testing at the Winter Nats, are you considering on releasing a modified JL Red Dot soon? If you are, do you have rough time window as to when you might do so? I would certainly be interested in acquiring one at the first opportunity! Hope to see ya at the next big race at 301 Raceway.
Regards
The JL Red Dot .12 is in stock. The modified version is also in stock. The engine will be available to order on the website tomorrow. This engine is a beast, and no worries on gas mileage, or durability.
Old 03-06-2007, 01:01 PM   #1162
Lil Paul's Avatar
Hey Uriah,
Thank you for all your support at the Winternats. I am working with Bruckner to get some of your motors in stock. You really do great work, and you stand behind your products, that is very important. I will keep you posted.
Lil Paul is offline   Reply With Quote
Old 03-06-2007, 01:07 PM   #1163
Grinder's Avatar
Default Ninja.12 engines in stock
The Ninja .12 T01 engine is in stock. The modified version will be in stock Monday. JL.12 Red Dot in stock. Modified Version is also in stock.
Old 03-06-2007, 04:23 PM   #1164
mugendude's Avatar
thanks grinder for providing me with a bad plus 35 at the state race it almost put me in the a main and it kept me in front of ashton which was really fun and challenging untill i nailed the back wall
murnan modified rb xenon R ballistic missle i love the smell of nitro in the morning
www.rc-racing.org
mugendude is offline   Reply With Quote
Old 03-06-2007, 06:11 PM   #1165
GMartinez's Avatar
Trader Rating: 85 (100%+)
Tommy you got to leave the walls alone
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 03-06-2007, 07:20 PM   #1166
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Sup tommy
Are going to be at the Port C. race ,if so you got my back bud.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 03-07-2007, 04:32 PM   #1167
shocker360's Avatar
Default Modified JL Red Dot Engine
Hi Uriah,
I didn't see the Modified JL Red Dot engine listed. What is the price for this engine? I am interested in purchasing one.
Regards
www.vorra.com
shocker360 is offline   Reply With Quote
Old 03-07-2007, 06:32 PM   #1168
Send a message via MSN to Fabian K
Hello, Mr Murnan
I would like to know if you have tested LRP engines like Z12R TEAM SPEC 2 or SPEC 3 ,
i am a distributor from Associated Electrics here in my country (Brazil) also for Jaco racing , so that is the reason that i use and race LRP engines on my races, i like the engine by the way a engine that you only have power on botton end rpm since you richen a lot the botton end needle .
so, can you made a good work on this engines, and how your feel about LRP Z12 engines
Thanks a lot,
Fabian Kaloustian
Fabian K is offline   Reply With Quote
Old 03-07-2007, 07:01 PM   #1169
afm
afm's Avatar
Originally Posted by Fabian K
Hello, Mr Murnan
Thanks a lot,
Fabian Kaloustian
Hello Fabian
Picco makes the latest Picco .12 engine in several fashions.
Original Picco:
Picco Evo2
Picco Evo2 Edoardo Picco Modified (Factory Modified called Edo Tuned)
And now for 2007 the New Picco Evo3 in both fashions.
What you would call designer, or made under specs:
IDM Evo2
LRP Spec3
Ofna JLR Red Dot
Mega Zx DsII Plus
Trinity Drake Edition
Solaroli Evo2
Moded or Tuned:
WP Tuned Picco Evo2 (Italy)
MR Tuned Picco Evo2 (Spain)
Maxy Modified Mega ZX DS II Plus (USA)
Murnan Modified OFNA JLR Red Dot (USA)
There could be others, but this is what I know so far, and all of them are very powerfull and competent engines which incorporate new lighter cranks, new carb, new conrod, new piston/ sleeve, and new head button.
Not sure if the LRP Z12R Team Spec 3 has all of this changes, becaue I've never seen one inside. Can you post pictures of the dissambled engine to see if it is the same as the JLR Red Dot that Uriah Murnan does modify??, because if so he allready works on them.
AFM
afm is offline   Reply With Quote
Old 03-07-2007, 07:47 PM   #1170
Originally Posted by afm
Hello Fabian
Original Picco:
Picco Evo2
IDM Evo2
LRP Spec3
Ofna JLR Red Dot
Mega Zx DsII Plus
Solaroli Evo2
Moded or Tuned:
AFM
AFM,
I see you know everything thanks about explanations
I will find the pictures that i have for my SPEC 3 inside and post here or LRP section(engine forum) , whatever you want
I know for sure that SPEC 3 is better (botton end, mid and high end power) than SPEC 2 I race LRP engines since the spec 1
the differences that i see lrp spec 2 to spec 3 are;
the top of the sleeve is longer ,to compensate, the burning room is also longer (inside ) to maintain same clearence- same head shims
the cranckshaft has black anodized on some parts with minor modifications
I do not know about timing if had changed
the conrod has two small risks on inside botton side like megas
the coolong head is little diferent
and back plate also
Maybe i forgot something but......
Fabian
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
