Old 12-29-2005, 01:08 PM   #601
Sandra's Avatar
Originally Posted by joemugen
chris, just out of curiousity, are you still thinking about building a track? if so, what's the progress so far?
Yes we are, but had to terminate a contract on 7 acres of land after 5 months of environmental studies, and alot of money, but we are still on the grind, looking for that right location and the right zoning.
Sandra is offline   Reply With Quote
Old 12-29-2005, 01:10 PM   #602
Sandra's Avatar
Originally Posted by Uneke
So Chris is gonna run 1/8th.
Just don't pull a stunt with that car like you did with your RRR at Doug's.
Yeah man I gonna give it a go, I can't run this one into the wall(on purpose) because I didn't buy this one, but wait I do have another MRX4 that I payed for so you know what that means
Old 12-29-2005, 04:56 PM   #603
Vinyard's Avatar
Default Converting a 5-porter into 3?
Hi Guys,
need to ask you engine gurus out there a question.
To convert a 5-port engine, say a nova LL5 into a LL3, is it as simple as just changing the piston and sleeve? or is there other mechanics that i got watch out for .. for eg, the crank shaft etc etc..
i mean taking into consideration of the engine timing of the 5-ports and the 3-ports and the rocket science stuffs like that.
thanks in advance
Vinyard is offline   Reply With Quote
Old 12-29-2005, 05:45 PM   #604
Grinder's Avatar
Originally Posted by Vinyard
Hi Guys,
thanks in advance
Yes, it is as simple as changing the piston and sleeve. As long as it is the same stroke engine. LS3 will not work in LL3, but LL5 will work in LL3.Novarossi 5 port crankshafts are better than the 3 port version.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 12-29-2005, 05:52 PM   #605
Grinder's Avatar
I forgot about my touring car when I started driving my 1/8th scale. It's the best. So what did it look like after the wall?
Old 12-29-2005, 08:36 PM   #606
Vinyard's Avatar
Thank you grinder.
Another question, right now i have a 5-port Max S5 engine. If i have to change it to a 3-port, i will just have to get a 3-port Max sleeve and piston right?
In the case where my LHS does not have the parts, what other alternative (brands, model) of 3-port sleeve n piston that will work with the Max S5 engine?
Old 12-29-2005, 08:43 PM   #607
Sandra's Avatar
Man you don't want to know, I did twice, chassis broke in half, motor shifted to the front and almost off all 4 front hinge pins were bent, 4 fins on the head bent, but it was alot of fun, end of the season and I had nothing better to do, plus I was going to rebuild the entire car and use the skyline chassis,BTW have you or anyone used that chassis, and what should I expect.
Old 12-30-2005, 05:20 AM   #608
Grinder's Avatar
The Skyline chassis is very good.
Old 12-30-2005, 06:40 AM   #609
Sandra's Avatar
OK cool
Old 12-30-2005, 03:51 PM   #610
dg8one's Avatar
Grinder
do you mod a HYPER 12 OFNA MOTOR? YES Sandra my spec motor
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 12-30-2005, 06:56 PM   #611
Sandra's Avatar
Originally Posted by dg8one
Grinder
Come Nelly you don't mod motor, you were doing just well with the spec motor
Old 12-30-2005, 09:15 PM   #612
dg8one's Avatar
i need something to keep up with you guys
TOKWA'T BABOY LTD
Old 12-30-2005, 09:27 PM   #613
Sandra's Avatar
Well your talking to the right man,Uriah
Old 12-31-2005, 08:31 AM   #614
Trader Rating: 15 (100%+)
Grinder
I thought that you have a X12? I would see about sending that one.
THE DOCTOR is offline   Reply With Quote
Old 01-02-2006, 06:00 AM   #615
Grinder's Avatar
I have never seen that OFNA engine. Not sure about it.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
