Old 11-28-2005, 01:37 PM   #541
rowveg36's Avatar
Trader Rating: 21 (100%+)
where can i buy those permatex rtv high temp silicon?
rowveg36 is offline   Reply With Quote
Old 11-28-2005, 01:38 PM   #542
GrandeGixxer's Avatar
You should be able to find it at any auto parts store.
GrandeGixxer is offline   Reply With Quote
Old 11-28-2005, 01:43 PM   #543
rowveg36's Avatar
thanks for the info: guys, appreciate the help.
Old 11-28-2005, 07:55 PM   #544
Grinder's Avatar
Originally Posted by rowveg36
yes, it is a mugen x12 that i bought from you. used it last paris racing here in las vegas.
If you send it to me, I will repair the engine for you.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 11-28-2005, 08:48 PM   #545
rowveg36's Avatar
uriah, you are the man!!! i would really appreciate the help. do you want me to send the whole engine or just the crank shaft it self?
Old 11-29-2005, 03:46 AM   #546
Grinder's Avatar
You can just send me the whole engine.
Old 11-29-2005, 08:05 AM   #547
rowveg36's Avatar
will send the engine today, thank you.
Old 12-06-2005, 10:22 AM   #548
Default pm
Uriah,
you have a pm.
thanks
mike
sedanaddict is offline   Reply With Quote
Old 12-15-2005, 02:52 PM   #549
rowveg36's Avatar
received the engine yesterday, thanks a lot uriah.
Old 12-15-2005, 05:41 PM   #550
JustRace's Avatar
[QUOTE=Grinder]You can use Permatex RTV high temp silicon to fill the void. QUOTE]
Hey Uriah...is this what most engine manufacturers use? I had a TOP motor that came that way.
BTW...the price of gas is coming down so you and Nick should head down to Florida
Francis
JustRace is offline   Reply With Quote
Old 12-16-2005, 05:58 AM   #551
Grinder's Avatar
[QUOTE=JustRace]
Francis
Hi Francis. I am not sure if we will make it down before Winternats or not. I would like to though. It seems that the engine manufacturers have some type of liquid RTV. The properties are very similar to the stuff you buy at the auto parts store when dry, but I think they are pouring it and letting it dry. I have found some pourable versions, but they will not withstand the fuel and temperature inside the engines. It takes some practice, but I can get the regular stuff pretty smooth, and especially on .21's.
If anyone out there knows of a liquid type RTV that will withstand fuel and temperature, lets here it.
Old 12-16-2005, 07:56 AM   #552
Data's Avatar
GE RTV 116 seems to work. silicone is inert to most chemicals anyways and the flowable 116 can withstand temperature up to 500F after curing. the only concern i have is the hardness, wish they make it higher than 28A but it work as is.
Data is offline   Reply With Quote
Old 12-16-2005, 09:48 AM   #553
stefan's Avatar
Send a message via AIM to stefan
The problem is not the heat, but the adhesion to the metal. Most silicones do not withstand our fuel.
I'm using the same stuff that Uriah is using (thanks for the tip a long time ago Uriah ) and it holds up great.
The way I get it modeled and smooth, is to take the rounded end of a medium size zip tie, spit on it and smoothen out the silicone the way I want it. Works pretty good.
You have to make sure that the surface inside the intake window of the crank is absolutely clean (break cleaner) dry and slightly rough/sanded, then the silicone will have excellent adhesion
stefan is offline   Reply With Quote
Old 12-16-2005, 10:17 AM   #554
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
He's not talking about the heat tolerance being the problem. He's talking about the hardness so it doesn't deform under the rotation of the crank.
Racing4Evo is offline   Reply With Quote
Old 12-16-2005, 11:18 AM   #555
stefan's Avatar
No he's not. Where do you think the silicone could go when the crank rotates?
Centrifugal force is pressing it into the crank, not out.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
