Old 05-13-2013, 09:25 AM   #3346
Grinder's Avatar
Originally Posted by choisan View Post
Thanks for clarification. How is it compared to the reds 2013 wc?
The reds has less bottom end compared to the M21. The Reds is no slouch though.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 05-13-2013, 09:29 AM   #3347
Grinder's Avatar
Originally Posted by victor1997621 View Post
Thank you. Is the engine very thirsty?
The Virtus is thirsty at first. After its fully broken in it starts getting better mileage. Some people can make 5 minutes, and some can't. Making 5 minutes with the virtus is possible if you drive smooth with the throttle.
Old 05-18-2013, 05:38 AM   #3348
Is the Murnan Modfied KEEP-ON.21 FULL CERAMIC using the original NOVAROSSI ceramic ball-bearings?
Capricorn LAB C801/OS ENGINES/FUTABA/FUTABA
victor1997621 is offline   Reply With Quote
Old 05-18-2013, 06:48 PM   #3349
Grinder's Avatar
The rear bearing is stock novarossi ceramic. The front begins as a steel novarossi bearing. The steel balls are replaced with ceramic.
Old 05-19-2013, 12:03 AM   #3350
Gday Uriah, got a 35 + with about 12litres threw it now, been running like a champ, absolutely love it. Today the rod let go on me, was running a bit rich sitting around 220 was running good, then lost a bit of power pulled in, leaned a bit another run then bang, just shut down game over, snapped in the middle and destroyed the brass bush and the rod. I know its a bit hard to say without seeing, but what are the causes for this type of failure, I am definitely the first cause. any help would be appreciated, Ill try and get a couple of pics up for you.
cheers Burty.
Forgot to add,i replaced the rod at 8 litres, should have done it sooner maybe???
cheers again.
burty is offline   Reply With Quote
Old 05-19-2013, 12:55 AM   #3351
stefan's Avatar
Send a message via AIM to stefan
That's your problem, right there
cheers Burty.
cheers again.
stefan is offline   Reply With Quote
Old 05-19-2013, 02:44 AM   #3352
Cheers Stefan, lesson learnt the hard way lol. thought it might have been my tuning, but it always ran brilliant, damnit, I knew I should have replaced it sooner, I am a tool. it was always in the back of my mind that the I should have done it sooner.
Ill definitely be getting another murnan anyway, was a sweet motor.
Cheers Burty.
Old 05-19-2013, 02:39 PM   #3353
Grinder's Avatar
Im sorry to see that. Hard to say what caused the failure. It could be a faulty rod, fuel. I replace the rods in the 35+21 each 4 liters if I'm pushing the engine.
cheers Burty.
cheers again.
Old 05-20-2013, 12:14 AM   #3354
Gday again Uriah, thanks heaps for all the help, I'm going to get another one of your motors and I was pretty set on getting another 35 +,but im torn between it and your M21 , tracks tight and short, M21 work well with nova 2015 and med header? What plugs for the M21? I've got a few c8tgh novas, but if I get the m21 would also like to get picco plugs.
cheers again for all the help.
regards Brad
Old 05-20-2013, 08:19 PM   #3355
Grinder's Avatar
regards Brad
Both engines are great. You can use the 2015/41016 on the M21, it works well. You can run the c8tgh, or Picco #7 plug in the M21. Both engines have awesome low end for a tight track.
Old 05-29-2013, 12:49 PM   #3356
just wanted to give another shout out to Uriah, excellent service and awesome products.
cheers Burty.
Old 06-13-2013, 06:50 AM   #3357
Grinder's Avatar
cheers Burty.
Thank you. Be sure to let me know how you like the engine.
Old 06-18-2013, 04:09 AM   #3358
What model RB is this? I can't find what it is and it's not on your website. The motor is supposedly brand new and is coming with the 2012 nt1 I just bought. He says there's less than a gallon thru it and IMO its not fully broken in if that's the truth. I paid $100 for it not including the car, did I get a good deal?
JOE SI is offline   Reply With Quote
Old 06-18-2013, 04:11 AM   #3359
Default Another pic
Sorry, pics aren't the best but I will post better ones when the cars in my possession
Old 06-18-2013, 08:16 AM   #3360
GREGORY!'s Avatar
This is Murnan's grenade.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
