Old 02-01-2013, 02:58 PM   #3286
HHH
HHH's Avatar
Originally Posted by Grinder View Post
The black stuff is most likely ground up metal particles from the bearing itself. You most likely got dirt in it somehow. What type of bearing was it?
I only clean the carbon if it is really thick, and looks like it could flake off. I only clean the top of the piston. I don't clean carbon off the side of the piston. Carbon on the piston would not be your problem in this case.
Thanks for the tip Uriah. It was a stock, blue rubber sealed front steel bearing from nova. Had 1.5 liters since was last changed. Was in the flash3 you modded over a year ago, which has been a real Mad Max/Road Warrior type of engine! Thanks.
HHH is offline   Reply With Quote
Old 02-02-2013, 12:33 PM   #3287
GREGORY!'s Avatar
Uriah? I need the bearings dimensions from the rb T10 engine. Thank you in advice.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 02-02-2013, 01:56 PM   #3288
Grinder's Avatar
Rear. 11.5x21x5
Front. 7x17x5
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 02-02-2013, 02:10 PM   #3289
GREGORY!'s Avatar
Rear. 11.5x21x5
Front. 7x17x5
11,5mm platform?i was thought that was 11.9mm.it is for a friend.thank you!
Old 02-06-2013, 08:34 PM   #3290
If i am not mistaken the T11 RS was the first RB .12 using the 11.9mm bearing.
"Drew Q."
~Team Durango~RCAmerica~Futaba~Trak Power~Murnan Modifieds~REDS Racing USA~Hot Race Tyres
automagic302 is offline   Reply With Quote
Old 02-07-2013, 02:53 PM   #3291
Grinder's Avatar
We have the Novarossi VIR-TUS engines in stock.
Let the testing begin!
Old 02-07-2013, 03:52 PM   #3292
GREGORY!'s Avatar
Make the graph-make the graph!!
Old 02-07-2013, 04:23 PM   #3293
Nice.....I wan't to read your opinion about this new engine.
GHN
ghn-sp is offline   Reply With Quote
Old 02-08-2013, 06:45 PM   #3294
Grinder's Avatar
Will do. Got to get it fully run in first.
Old 02-08-2013, 07:06 PM   #3295
Grinder's Avatar
GHN
So far the engine looks great. Usual Nova quality, the offset carb is interesting. Its expensive. I'll let you know as soon as I get it run in, and run it on the track.
Old 02-17-2013, 06:07 PM   #3296
kmh
Do the murnanmodified modified engines require further break-in. In other words are they broken in upon purchase. Thanks in advance.
kmh is offline   Reply With Quote
Old 02-17-2013, 07:15 PM   #3297
Grinder's Avatar
My modified engines are not run in. I do offer a break in service if you prefer a pre broken in engine.
Old 02-18-2013, 08:09 AM   #3298
spenzalii's Avatar
Send a message via AIM to spenzalii
Need even more power Ken? Let me know where you and the other guys are running this year. I need to get back to the track and race at least once this year.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-18-2013, 08:02 PM   #3299
Just wondering with the .12 engines which engine you recommend has the best all over performance package out of your modified units.
Also which engine is the best out of the factory before you modify them from your experience.
Blown1940 is offline   Reply With Quote
Old 02-18-2013, 08:02 PM   #3300
sorry double post
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
