Murnan Modified Motors
#3271
Does the new M21 use the same con rod as 2012 model?
#3272
#3273
When running in an engine on the bench, how do you reduce/deal with the noise?
#3274
I'll post a picture in a while.
#3275
Hi all, bit new to this so bear with me. I've currently got a 747 with the mega zx12 , looking to upgrade for the new season, I have spoken to chris the murnan dealer in Ireland but still don't know which engine to go for. I like the looks of the nova keep on, I will be racing at the halifax track. Also could you give me a price with it run in. Many thanks
#3276
#3277
I pipe the exhaust through a tube outside. The tube goes into an old fuel can with holes poked in it. That can is inside of another larger plastic box. This reduces the noise significantly. I also wear ear protection when I'm inside the shop, and the rpm is high. The noise outside the shop is not loud enough to be concerned with. Inside the shop is a different story. Hence the hearing protection.
#3278
Thanks for that, a pic would be brilliant
#3279
#3281
#3283
I need to say , That the RBM3 2013 FULL CERAMIC , its on another level of power , today i run for the first time this engine and its awesome , It give me 5:50 Min of run time in the little rich side at about 128 Celsius Degrees , and i took the win by 5 Laps กก
Thank You Uriah for the incredible engine you sent me !!!!!!
Adrean Zavala
Adrean Zavala
#3284
Hi Uriah,
I had a new front bearing go halfway into a main. Upon inspection the bearing was covered in blackish stuff.
The only thing I can think of is carbon from the buildup on top of the piston or dirt came in the front of the bearing? Any guesses?
Do you clean the top of your pistons to remove carbon build up?
Thanks,
Sam
Thanks,
Sam
#3285
Hi Uriah,
Thanks,
Sam
Thanks,
Sam
I only clean the carbon if it is really thick, and looks like it could flake off. I only clean the top of the piston. I don't clean carbon off the side of the piston. Carbon on the piston would not be your problem in this case.
