Murnan Modified Motors
#3241
I have checked the shift point, and clutch engagement points with tachometers. Nova makes one that is very accurate. It's mechanical. I have also used audio tachometers over the years. They are not as accurate as the nova mechanical tachometer.
The use of a tachometer over the years has let me know what 6000, to 50,000 sounds like. You can also look at the tach exactly when it engages.
#3242
I would adjust the engagement point to the level of grip. Usually on a small high grip track, I would use a strong clutch. On low grip, a softer clutch will limit wheelspin.
#3243
It has a rubber tip, that you push against the end of the crank. It catches the 2.5mm screw that holds the clutch on. It spins the tach, the exact rpm of the engine. It can also be used as an optical tach.
#3244
Grinder,
Do you still modify Picco Torque .12? I did not see them in your normal inventory. What are your thoughts on this engine compared to your MM keep-on and RBM3.
Thanks!
Thanks!
#3245
It is on my webpage. I must have been updating the site when you looked.
#3246
#3247
One last quick question. Do you recommend the picco 2669 or the nova 2660 with the picco torque .12?
#3248
Dear Grinder
Does this running in procedure also goes for the REDS M7T ... it's a Picco based engine, and I want to go after engines wich is easy to break in.
Best wishes; Jens
Best wishes; Jens
The M21, and XZR have similar power bands to each other after they are modified. The M21 has the edge on power over the XZR.
The M21, and XZR don't like to be run on the prop as long as some other engines. Heat the M21 up to 200F cover the head, and let it run on the prop at a low-medium rpm for no more than 500CC. Then put it in the car, gradually reach race tune over 5 to 10 tanks. The M21, and XZR are both much easier to break in than most engines.
A long, cold break in will damage the Picco M21 engine. Picco himself only runs a couple of tanks rich, then gradually reaches race tunes over the next few tanks.
The OS can be done the same way. I would not recommend this with most engine brands. Most engines need up to a .5 to 1 gallon of fuel, before you start leaning on them.
#3250
#3251
#3252
Dear grinder , just finish run in your modify keep-on 21 really love the the low end power .the power worth every drop of nitro . I'm using 2015 pipe with the 5 fin manifold ,can I use Rb 2092 or 2018 with the short manifold will it be better?
#3253
Boss,
What is difference between modified Novarossi 35+21 and modified Novarossi Collari WC09 35+21 ?
#3255
I'm glad you like the engine. I have not tried either of those pipes. I have been happy with the 2015. Please try them, and let us know how it feels with those pipes.
