Old 04-24-2012, 11:39 PM   #3136
FaanP's Avatar
Originally Posted by tq23 View Post
does anyone here help me with this..has anyone here tried the .12 picco EDO and the reds M3T?they're both picco based..just wanna know wat difference Edoardo and Mario has done to these engines.thanks
Don't think the M3T is Picco based - as far as I know it is Sirio based. Talking under correction though
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 04-25-2012, 03:10 AM   #3137
wingracer's Avatar
Trader Rating: 22 (100%+)
They used to be but now they have switched to Picco.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-25-2012, 07:01 AM   #3138
Grinder's Avatar
They are the same base engine. Mario does more hand tuning work with the reds. The EDO mods look to be done more by machine. Both have filled, un-balanced crankshafts. Same Piston/sleeves/heads.
The reds crank does not have the 2 upper turbo scoops.
They are different, and they run different. Both are good engines. Both the EDO, and the M3T respond well to my modifications. They go from pretty good, to insane.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-26-2012, 05:00 PM   #3139
G87z's Avatar
I assume the Sonic engines are in the same class too?
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 04-29-2012, 01:31 AM   #3140
hi some of the boys in AUS have had leaking fuel around base of carburetor on reds that is hard to stop is it just us or have some won else had same problems tried two rubber rings but it still leaks
greg
greg.dawn is offline   Reply With Quote
Old 04-29-2012, 02:45 AM   #3141
kickass's Avatar
greg
Greg I think you'll find that it is actually leaking from where the nipple screws into the carby nip this up or put a little sealer on it and your problem will go away, I had the same issue and it looked like the base of the carby.
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 04-29-2012, 07:57 PM   #3142
Adrean's Avatar
Uriah , Well maybe its a stupid question but need to hear it from you , which engine its faster the RBM3 2012 FULL CERAMIC , or the New Murnan Modified KEEP ON .12 FULL CERAMIC ? im going to buy one but cant decide .
thanks
Thanks to My Sponsor ---------- Capricorn America -------- Capricorn RC CARS
LAB C03/TESLA ENGINES
RCTARGET
Adrean is offline   Reply With Quote
Old 04-30-2012, 02:44 AM   #3143
rc carnage's Avatar
thanks for the info kickass, i think greg was talking about an engine that i have and your right it does look like it comes from the bottom of the carby
JT
rc carnage is offline   Reply With Quote
Old 04-30-2012, 06:36 AM   #3144
Grinder's Avatar
Most likely. I have yet to see the internals of a sonic engine though.
Old 04-30-2012, 06:41 AM   #3145
Grinder's Avatar
thanks
If you plan to race on small, or medium tracks the MM Keep On is the best engine. If you plan to race on large tracks the RBM3 is the best choice.
The RBM3 is the king of peak power, and rpm. So it has it's place on the larger tracks. The MM Keep On has tons of instant bottom, and hardcore midrange with decent top end.
I will have to leave which engine to choose up to you. Personally, I have the RBM3, and the MM Keep On .12 in my pit box.
Old 04-30-2012, 06:43 AM   #3146
Grinder's Avatar
greg
Did you determine where the leak is coming from?
Old 04-30-2012, 12:07 PM   #3147
spenzalii's Avatar
Send a message via AIM to spenzalii
Just ordered a +12 P/S/R combo to rebuild my trusty Nova. Hope to have it installed and broken in by time I go for my first race in 3 years in May down in Richmond.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 04-30-2012, 01:56 PM   #3148
Grenade10's Avatar
Trader Rating: 37 (100%+)
What kind of sealer do you use / recommend???
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 05-01-2012, 03:48 AM   #3149
kickass's Avatar
Hi Uriah,
How do you compare these 2 to your Reds and EDOs.
Old 05-01-2012, 08:03 AM   #3150
T-BODZ Terry B.'s Avatar
Thumbs up M21 2nd in RCPro On-Road US NATS 1 Hour Final!
Special thanks to Uriah for sending me a missile!
It has been several years since I have run a Picco based Engine. Uriah's M21
Engine produced plenty of power and a ton of rip out of the corners with plenty
of straight away speed. The Bonus, it had good fuel mileage giving me an additional
lap after 5 minutes to insure that I would not run out.
I qualified 4th for the 1 hour final behind Scott Kimbrow, Ralph Burch & Jeremy Cupps.
I finished the 1 hour main in 2nd behind Scott Kimbrow. The engine performed flawlessly
throughout the weekends Qualifying & Final. Very Reliable with no issues!
Thanks again Uriah!
Brother T
Special Thanks to Sponsors: Mugen Seiki USA, Futaba America, Murnan Modified Motors, VP-Powermaster Fuel & Faskolor
T-BODZ Terry B. is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
