Old 12-18-2011, 09:39 AM   #3061
Grinder's Avatar
Originally Posted by afm View Post
The shape and size of the turbo scoop will affect the gasification of fuel. i.e. small size = high flow and will improve gasification but reduce the flow speed.
If the turbo scoop has been cut beyond the sweet point, fuel will be excessive and stay in the lower chamber. That is the case of flooding at low rpm...
The size of the crank hole and scoop is directly related to crankcase volume , size and number of transfer ports, and it will affect positively or negatively the maximization of gas mass flow and speed, from the case through the ports and into the combustion chamber.
So if badly done there will be losses and no gain. If properly done, even minimal gains will be gained.
AFM
That's true. If done improperly, power will be less.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 12-19-2011, 08:07 AM   #3062
YBSLOW's Avatar
Originally Posted by Grinder View Post
Here is a short video of one of my Novarossi 35+21's on the dyno.
http://www.youtube.com/watch?v=htaW_...qtwPWmdNd9huyq
cool video........
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel,
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 12-19-2011, 11:48 PM   #3063
FaanP's Avatar
Default M21
Why is everybody so quiet on the M21? I'm nearly done with my bench break-in and I'll put it on the track early next year.
Anybody racing it yet?
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 12-23-2011, 11:36 AM   #3064
Grinder's Avatar
All the reports are very positive. The engine is fast. You will have to keep us posted.
Old 01-08-2012, 09:22 AM   #3065
FaanP's Avatar
I ran 2 different motors the past week, the M21 and a Murnan 35+ and to be honest - there is not much difference between the 2. The M21 is a monster!!
Old 01-08-2012, 10:19 AM   #3066
When you say that there's not much difference but then say the M21 is a monster..............uhmmm you are confusing me at least. What makes the M21 a monster? I am assuming the 35+ is a monster too then?
Brent Davis is offline   Reply With Quote
Old 01-08-2012, 10:40 AM   #3067
Confusing me too.
redliner140 is offline   Reply With Quote
Old 01-08-2012, 10:57 AM   #3068
Grenade10's Avatar
Trader Rating: 37 (100%+)
So what you are saying is that the M21 is a match for the modified 35+21. How is the fuel economy of the M21? My Munan 35+21 is a little thirsty. What header and pipe were you using with both engines? Size of track, lap times.
Just wanting to compair to where I will be running this summer.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 01-08-2012, 02:02 PM   #3069
staikosn1's Avatar
Send a message via MSN to staikosn1
Good evening!
Grinder how you compare RB T10 RC - T11 RS??
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 01-09-2012, 10:20 PM   #3070
FaanP's Avatar
Track: Quick track with long sweeping corners and one tight section - not to sure about the length.
Running both engines with the Novarossi 2015 pipe with medium conical header.
The fuel consumption on the M21 is better.
The bottom end power of the Murnan 35+ is a bit better but the M21 match the 35+ through mid and top end power - or that is how it feels to me.
Can't tell you about lap times since both days were practice days with no timing.
Old 01-10-2012, 05:42 AM   #3071
Grenade10's Avatar
Thanks! I was thinking about getting one and now it's on the top of the purchase list for the year.
Old 01-10-2012, 07:18 AM   #3072
Grinder's Avatar
Originally Posted by staikosn1 View Post
Good evening!
The T11RS has more bottom end power than the T10RC. Both have very good top speed. I would go for the T11RS.
Old 01-10-2012, 07:28 AM   #3073
Grinder's Avatar
Both the MM35+21, and M21 are great engines, and have lots of bottom end. Most people feel the M21 has more bottom than the 35+21. I like the new Picco 2069 pipe on the M21. It makes lots of power. The Werks 2058, and Novarossi 9886 are some more top pipes to use on the M21.
Old 01-10-2012, 07:50 AM   #3074
staikosn1's Avatar
Thank you for the reply!!
Which pipe do you suggest?
Old 01-11-2012, 05:59 AM   #3075
Grinder's Avatar
The RB2668 pipe with short header combo is the best I have tried.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
