Old 07-27-2011, 04:23 PM   #2896
Grinder's Avatar
Originally Posted by rx7ttlm View Post
hey grinder, do you have the ability to get a case for a MAX RR3? If so I might have you work your magic on that thing for my club engine
Cheers,
Patrick
I'm not sure if I can get that block. I'll check. What happened to the block?
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 07-27-2011, 06:20 PM   #2897
ToysRUsKid's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to ToysRUsKid
Originally Posted by Grinder View Post
I just add castor oil to 16, or 20% until the correct percentage is reached. I can break in the engine for you if you like. Just let me know.
For the one coming, please do. Give me a call when you check it out and let's talk about what you can do
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 07-27-2011, 06:21 PM   #2898
ToysRUsKid's Avatar
If not I can sell him a XXL3 block.
Old 07-28-2011, 02:20 AM   #2899
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
my bad, I ment xl3. I purchased it from someone on the forums and the case is unusually tight. The back plate is even a challenge to remove which from what I have seen is unusual in the 10 or so high end nitro engines I have had. I suspect they flipped the car and it took a good hit tweaking the block. So now the question is is an XXL3 case compatible with the XL3?
Cheers
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 07-29-2011, 07:48 AM   #2900
ToysRUsKid's Avatar
Cheers
Sent you two PM's. let me know if you still want the parts.
Old 07-29-2011, 09:09 AM   #2901
Grinder's Avatar
I did not get a pm from you today. You can email me at
uem11@yahoo.com
Old 07-29-2011, 09:33 AM   #2902
ToysRUsKid's Avatar
uem11@yahoo.com
That was for rx7ttlm, you got PayPal!
Old 07-29-2011, 02:22 PM   #2903
Grinder's Avatar
Old 07-31-2011, 10:07 PM   #2904
rx7ttlm's Avatar
Hey grinder, do you have an alternate piston/ sleeve that works in the xxl3 other than the max? maybe like the 353 etc?
Old 08-02-2011, 12:31 AM   #2905
R3VoLuTiOn's Avatar
Trader Rating: 26 (100%+)
if im running 30% nitro,
and the engine is not shimmed for it, would it run cooler or hotter than it should?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 08-02-2011, 04:45 AM   #2906
Grinder's Avatar
The 12-3sct piston/sleeve should fit that engine.
Old 08-02-2011, 04:50 AM   #2907
Grinder's Avatar
The engine will run cool while the engine is rich, but rapidly overheat when you start to lean it for max performance. If you are drag racing you can get by with low heads, and high nitro. If you are racing a circuit, the head clearance becomes more critical due to the sustained running.
Which engine are you running, where is the head clearance?
Old 08-02-2011, 09:21 AM   #2908
ToysRUsKid's Avatar
Maybe I'm over thinking it but doesn't it matter which version of the max you're referring to? 2010, WC, etc.? I thought they were slightly different.
Old 08-02-2011, 06:30 PM   #2909
rx7ttlm's Avatar
I think the ps for the wc just has different timing etc. I think the head, head button and timing on the ps changed for the wc engine.
Old 08-02-2011, 06:55 PM   #2910
Grinder's Avatar
You can send me your max to be sure. I'm pretty sure the ps is the same as the +12.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
