Old 06-27-2011, 10:57 AM   #2866
Grinder's Avatar
Originally Posted by JETT View Post
Uriah, which one of your modified P/S sets would you recommend for my RB10 RC?
Some novarossi sets work also, right?
You can use the modified +12-3sct psr set.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 06-27-2011, 06:31 PM   #2867
firecat's Avatar
hello uriah
i.m currently running a stock t9/2604 combo I have a brand new t9 never been run. the stock t9 runs good but cant quite keep up with the max and nova tuned motors. my question is similiar to jetts which of ur modded combo.s would work in the new t9 and why would u put a modded sct combo in a t10 instead of a rb combo I realize both are nova based motors also have a nova 2652,2660 pipes sould I use one of these instead of 2604 or just have u mod the new t9 thank you
team scream racing/ts racing/kyosho mp9 tki3/ xray xb2 xb4/Wolcott hobbies and airsoft/rc madness
firecat is offline   Reply With Quote
Old 06-29-2011, 04:22 PM   #2868
Grinder's Avatar
Originally Posted by firecat View Post
hello uriah
The T9, T10, T11, and +12 all use the same Piston/Sleeve/Rod set. If you send in your T9, I will make it run with the best of them.
I like all of the pipes you mentioned, but the 2652, and 2660 work exceptionally well with the modified RB T series engines.
Old 06-29-2011, 04:31 PM   #2869
Grinder's Avatar
Old 06-29-2011, 08:00 PM   #2870
firecat's Avatar
thanks for reply will be getting in touch with you to send you my T9 for mods thanks again
Old 07-13-2011, 12:05 PM   #2871
Grinder's Avatar
Default Murnan Modified Motors TQ, and Win at Novarossi Challenge
Congratulations to Diatta Collymore. He TQ'd, and won nitro sedan at the Novarossi Challenge held by Control Freakz Raceway in Chaplin Connecticut. Diatta was using the Murnan Modified RBM3.
Congratulations to the other Murnan Modified drivers that made the A main at this event.
Old 07-19-2011, 09:21 AM   #2872
etgdpu's Avatar
Default Ins box theoretical question 0.12 engines
Hello all,
It's been a while since when the air filter has to be installed in an ins box for the 0.12 engines, according to the regulations.
If it was allowed to run a 0.12 without the ins box, would you do it or the engines are designed to work with the ins box and they perform better with it?
Thanks in advance
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 07-19-2011, 09:29 AM   #2873
wingracer's Avatar
Trader Rating: 23 (100%+)
If you don't need it, don't run it. An INS box acts just like dropping the venturi size a couple tenths of a mm so unless you need it to make run time, go without.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-19-2011, 11:30 AM   #2874
Grinder's Avatar
Yep. Don't run it if you don't have to. It decreases power slightly.
Old 07-20-2011, 03:25 PM   #2875
Default need some advice
I have a 35+21 MM, it came with a 0.1 shim making the clearance in piston to 0.6 (using solder method) , should I remove the 0.1 shim to get to 0.50 clearance for a short track and use the 0.1 shim for a large track? I am using 25% nitro
Also a friend that was helping me out at the track must of accidentally moved the middle sleep needle , where does the middle speed needle sit normally?
uneek is offline   Reply With Quote
Old 07-20-2011, 07:33 PM   #2876
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
hey uriah,
do you do motor checkups? my T10RC seems a little sluggish and I'm not sure why.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 07-21-2011, 08:16 AM   #2877
Grinder's Avatar
The 35+21 comes with the following head shims stock, and Murnan Modified.
.1mm = 1
.3mm = 2
There is a total of .70mm of head shims in the engine. That makes .60mm of actual head clearance most of the time. You should not remove any shims from that engine for your application.
The middle needle should be exactly flush with the carb body.
Old 07-21-2011, 08:18 AM   #2878
Grinder's Avatar
Originally Posted by ToysRUsKid View Post
hey uriah,
Yes, I do checkups. You can send it to the address listed on my website. Please put a note inside the box with your contact info, and what you want me to do with the engine.
Old 07-21-2011, 10:30 AM   #2879
ToysRUsKid's Avatar
Ok, I'm racing this weekend so I'll be calling you on monday to discuss what I need
Old 07-25-2011, 08:49 PM   #2880
ToysRUsKid's Avatar
I'm putting my motor in the mail first thing in the morning. I'll call you to discuss sometime this week. I'm using the address on your website.
1679 Elmwood Drive
Austell, GA 30106
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
