Old 03-30-2011, 06:31 PM   #2821
quietstorm76's Avatar
Originally Posted by Grinder View Post
Not yet. I have been extremely busy trying to get ready for the WC. Right now there is not enough time in a day.
I will dyno the engines when I return from the race. I should have some results of the testing by the end of April. I have been doing lots of on track testing, and they are fast. Good on fuel too.
Dude I feel you, worlds prep is a pain and expensive I'm in no rush, you just get that 5 ready.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 04-04-2011, 03:39 PM   #2822
Grinder's Avatar
Default IFMAR 2011 1/8 I.C Circuit WC
We will be away racing, and supporting the Murnan Modified Motors team at the IFMAR 2011 1/8 I.C. Circuit World Championship. All orders placed from 4-4-2011 to 4-17-2011 will ship Monday April 18, 2011. Thanks.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-12-2011, 09:44 AM   #2823
lil-bump's Avatar
Trader Rating: 82 (100%+)
I have a Murnan RBM3. Will the carb insert (01250-9tr505a) fit into a Novarossi carb. The original carb failed and I forgot to take out the insert before I tossed it.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-12-2011, 07:04 PM   #2824
NitroWD's Avatar
Default 7604 in RBM3
can the nova 7604 rod fits the RBM3?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 04-13-2011, 05:31 AM   #2825
lil-bump's Avatar
I just ordered a P/S/R set for my Murnan RBM3 from Murnan. It uses the same set from the Nova 3sct. The Nova 3sct used a nova 07601 rod. So I would say no. I believe the 353 uses 7604 rod.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-13-2011, 04:40 PM   #2826
Grinder's Avatar
Pass you soon...
Yes. The insert will fit the standard novarossi carb. It will fit in most .12 carbs.
Old 04-13-2011, 04:42 PM   #2827
Grinder's Avatar
No. That rod will hit the bottom of the block under high rpm use. The bottom of the rod is too big.
Old 04-13-2011, 07:00 PM   #2828
lil-bump's Avatar
Thanks for the reply,, Good luck!!!!!
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-20-2011, 08:25 PM   #2829
ralphierace13's Avatar
if u advance the timing of a motor by 1 degree, what would b the down side assuming it didnt work, and didnt work i mean not like u didnt do it right just wasnt good for the motor, would u loose bottom end or top or both or would it just do nothing.
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 04-21-2011, 04:21 AM   #2830
Grinder's Avatar
You would start to see a loss of bottom end, and throttle response. Are you cutting on your engines?
Old 04-21-2011, 08:42 AM   #2831
u got a pm
RALPH FORTUNATO
Old 04-22-2011, 05:44 AM   #2832
Grinder's Avatar
u got a pm
Old 05-03-2011, 05:32 AM   #2833
Uriah,
last weekend I ran one of your modded Kangaroos at a national event. The engine ran very well with laptimes that were comparaple to other top engines.
Now, after I disassembled the engine I found that the piston has a small "scratched" area on the exhaust side slightly below the brown ring of carbon build-up in the compression area. Those two grooves (oil-rings) are ground flat in this small area. Maybe the engine was a little bit lean....
What are my options here? The engine is still running fine and the sleeve looks good. Should I just continue to run, or buy a new unmodded Kangaroo to get cheap spare parts?
Would it be a good idea to take a new piston from another Kangaroo and break the "repaired" engine in again, or would it be better to change piston + sleeve and loose the benefits of the modded sleeve. In any case, the benefits of the Murnan cank would still make it a good engine....
Thanks for your feedback!
Best regards, Stefan
fulcrum2 is offline   Reply With Quote
Old 05-04-2011, 05:20 AM   #2834
Grinder's Avatar
Originally Posted by fulcrum2 View Post
Uriah,
Hi. I'm sorry to hear about the piston problem. The Kangaroo has a microcast piston, and it is more likely to have a problem like that. I have seen that happen to them. I suspect that the engine was over revved before it was fully warmed up, or run too lean before it was fully broken in. I suggest that you replace the piston, and sleeve with a new one if possible. Usually when the piston gets scratched, the engine will not idle, and loses power.
You will still have more power than a stock Kangaroo with just the modified crank, but the modified piston, sleeve will make it even better for sure.
If you feel that the engine is running fine, you may want to continue to run it. Did the scratch damage the oil rings in the piston?
Old 05-04-2011, 06:16 AM   #2835
Hi Uriah,
thanks for your speedy follow-up, much appreciated. Yeah, the oil rings are polished (which means they are gone) in a small spot. At the very top, the piston is OK, the narrow brown ring is still there.
I will run the engine one more time and will monitor closely how it behaves. If it starts to act up, I will buy a new OEM Kangaroo and use the piston/sleeve set.
Thanks again and best regards, Stefan
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
