Old 03-27-2011, 08:27 PM   #2806
who is the australian importer of theses motors
rufazz is offline   Reply With Quote
Old 03-27-2011, 09:09 PM   #2807
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
There is no Australian importer for Murnan. You order them directly from his site.
Michael.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-28-2011, 04:18 AM   #2808
Grinder's Avatar
Originally Posted by ralphierace13 View Post
is the piston and sleeve in the tuned kangaroo the same as the reg kangaroo?
It's the same in novarossi's tuned. The sleeve is modified on the Murnan tuned.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-30-2011, 05:25 AM   #2809
Grinder's Avatar
Default IDM EVO4 Engines in stock now
We have just received the new IDM EVO4 .21 On Road engines. We have the stock, and factory tuned versions.
Old 03-30-2011, 03:02 PM   #2810
quietstorm76's Avatar
By chance are you going to do any dyno testing on these? I know what they will do on the track, just curious what the chart would look like compared to a 35 plus and a Flash .21.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 03-30-2011, 03:08 PM   #2811
ralphierace13's Avatar
just got some lineer shims the ones go under the sleeve used a .1mm motor felt alittle more perky felt like i got some more mid-top out of it. now my ? is when u raise the sleeve i know it changes the timing, but does it also give alittle less compression cause the button head is alittle further away from the piston? also can i take out a .1mm head shim what will that do? thanks
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 03-30-2011, 03:13 PM   #2812
DS Motorsport's Avatar
If you add a 0.1mm shim under the liner you will also need to take out 0.1mm of head shims. Otherwise you'll change the compression ratio as well.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-30-2011, 03:14 PM   #2813
nitrodude's Avatar
No, you raised the sleeve, and the combustion chanber rests against the top of the sleeve, so by raising the sleeve you raised the CC along with it. Therefore no head clearance change.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-30-2011, 03:18 PM   #2814
The head clearance does change. As you said you are raising the sleeve plus head button but the piston stays in the same spot, TDC height remains the same. Therefore you will have more room between the top of the piston and the headbutton. This will change the compression ratio.
P1-RC.com
Old 03-30-2011, 03:40 PM   #2815
nitrodude's Avatar
Good point. Wasnt thinking about the stroke
Steven Muller
Ronin Speed Parts
Old 03-30-2011, 04:02 PM   #2816
Grinder I race the 1/8 GT class and need a new motor for the Nats in October. I have a RB that you modified in the GT right now that is just awsome but I don't know wish one is it since I bought it used. All I know is that it was an offroad motor. Wish motor do you recommend for this particular class? I talked to you last year about it in a race here in PR but couldn't get in touch with you then.
jneg is offline   Reply With Quote
Old 03-30-2011, 05:02 PM   #2817
Grinder's Avatar
Not yet. I have been extremely busy trying to get ready for the WC. Right now there is not enough time in a day.
I will dyno the engines when I return from the race. I should have some results of the testing by the end of April. I have been doing lots of on track testing, and they are fast. Good on fuel too.
Old 03-30-2011, 05:03 PM   #2818
Grinder's Avatar
Old 03-30-2011, 05:07 PM   #2819
Grinder's Avatar
If you want an engine with too much power try my modified Fusion X28. So far in on track testing that engine is blowing tires, and transmissions in IGT cars, but extremely fast. For something fast, and smooth try my modified Novarossi Kangaroo.
Old 03-30-2011, 06:04 PM   #2820
I will then try the Kangaroo. I preffer a .21 since they have more than enough power for the rubber tires we use. Plus fuel milage is another consideration. The RB engine that I have from you is an offroad engine and it does really good on power and milage departments. BTW I have won all three races this season and I think one major reason is your motor reliability and power.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
