Old 12-24-2010, 06:39 AM   #2746
Grinder's Avatar
Originally Posted by fulcrum2 View Post
Hi Uriah,
Novarossi came out with a new plug, dubbed "C8TGH". Have you had a chance to try it with your engines?
I am still struggeling to find good glow plugs since Nova's quality went south.
Which plugs do you recommend for the MM Kangaroo and 35+21 in typical northern european conditions (From 60F to 85F; 55% humidity).
The OEM Kangaroo comes with a Nova 6 plug. I assume that you recommend a cooler one after your modifications, right?
Thanks a lot and best regards, Stefan
Hi. Yes, we have tried them. They are really good. Very durable compared to past Novarossi plugs.
After break in I do suggest running the C8TGH plugs in most on road .21 engines, in most conditions. They work great!
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 12-24-2010, 06:41 AM   #2747
Grinder's Avatar
Originally Posted by HoboShop View Post
Hey Uriah what is the better buy? What is faster? Murnan rb c10 or Murnan flash?
The MM Flash, and MMC10 are very comparable to each other. The Flash has a little more low end grunt, and the C10 has slightly more top end power.
Old 12-24-2010, 12:31 PM   #2748
RoyalPalmRacer's Avatar
Trader Rating: 27 (100%+)
Default RBM3 Conrod
What conrod would you recommend for the RBT10RC and the RBM3 v1? Thanks
Sean B.
#86
RoyalPalmRacer is offline   Reply With Quote
Old 12-29-2010, 06:16 AM   #2749
Grinder's Avatar
You can use the following connecting rods in both engines.
RB 01700-171
Novarossi 07601
Old 12-30-2010, 01:27 AM   #2750
Default Conrod wrist pin
Hi Uriah,
does it make any difference in which direction the wrist-pin is put in?
Normally Nova ships all pins with the open hole towards the front of the engine. The Kangaroo which I just received from you has the hole facing towards the rear (exhaust side)...
Thanks for your feedback!
Stefan
fulcrum2 is offline   Reply With Quote
Old 12-30-2010, 02:26 AM   #2751
Roelof's Avatar
Send a message via ICQ to Roelof
I do always face the opening to the intake port so it does get some fresh fuel for an extra cooling from inside the pin and so the bushing of the rod.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 01-04-2011, 08:28 AM   #2752
Grinder's Avatar
Hi Uriah,
Stefan
Hi. Novarossi sends engines with the opening to the front most of the time. They send the opening to the rear about 25% of the time. I have not found any performance, or reliability difference whether it faces front, or back.
Old 01-04-2011, 08:31 PM   #2753
What is your opinion on the 16% Powermaster Fuel as compared to the others on the market?
Sean B.
#86
Old 01-05-2011, 06:40 AM   #2754
Grinder's Avatar
It is the best fuel I have ever tried, and I have tried a lot! It is very fast, and offers awesome protection from wear. I use Powermaster 16% in my .12 engines, and Powermaster 25% in my .21 engines. I must say that everyone who has tried it loves it. I also like the fact that it is factory sealed, with no chance of any air getting in. There are many years of experience, and some special chemicals involved in making this fuel, and it shows. It's FIRE!
Old 01-05-2011, 05:56 PM   #2755
keavze's Avatar
#8 plug? with stock head shims?
won't the lowend or idle be a little too tricky to tune?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 01-06-2011, 02:04 AM   #2756
Thanks a lot Uriah - Then I will run it the way Nova assembled it...
Old 01-06-2011, 07:13 PM   #2757
Grinder's Avatar
I am using stock head clearance with the c8tgh plug. It works fine for my team, and I. Still easy to tune, and very durable with the larger wire diameter.
Let me know if you have any tuning issues when you try them, I can help you through it.
Old 01-10-2011, 09:16 AM   #2758
ralphierace13's Avatar
does the 8 plug make alittle less power?
uriah how was miami?!!!
RALPH FORTUNATO
MUGEN SEIKI MRX6 TEAM DRIVER
Futaba 4PK-S-R, Novarossi Team Driver, CONTACT TIRES
Byron Fuel, Veytrex Desgin Labs
2014 R.O.A.R. REGION 1 CHAMPION!!
ralphierace13 is offline   Reply With Quote
Old 01-10-2011, 10:06 AM   #2759
wingracer's Avatar
Trader Rating: 22 (100%+)
It should make a bit more top end but a bit less low end.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-10-2011, 04:27 PM   #2760
since were on the subject of plugs what will a long body nova do compared to a short body plug?
RALPH FORTUNATO
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
SEO by vBSEO 3.5.0
