Old 03-17-2010, 02:37 PM   #2566
rcpanama's Avatar
Originally Posted by Grinder View Post
How many head shims are you using?
Thanks, Grinder for your responce, I am using .3
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 03-17-2010, 03:00 PM   #2567
afm
afm's Avatar
Originally Posted by rcpanama View Post
[SIZE=3][FONT=Calibri]
the conditions we have in Panama, are the following
Temperature 32º C
Humidity 85% to 92%
Sea Level from 10m to 52m
RCPANAMA
Indepedently to Uriah's advice on tuning your engine, this is what you need to know about chosssing the correct glow plug....
Turbo Glow Plugs where designed to give more performance to an engine, for the following reasons:
•It forms an uninterrupted combustion chamber.
•The advantage of better heat transfer or heat dissipation, and a leak proof seal, generated by the conical seat of the plug.
•Greater choice of thermal ranges, that allow for a more precise tuning according to variations in weather conditions (temperature, humidity, altitude, barometric pressure, etc.).
The numbers and characters on the plugs, are the product number, wire thickness, and thermal range of the plug’s body. Example:
The Novarossi C7TG (F) or (C)
Product: C (Conical)
Wire Thickness: 7
Plug Type: T (Turbo)
Plated:G (Gold)
Thermal Range: F (Fredda = Cold) C (Calda = Hot)
The plugs with cold thermal range F (Fredda), have a body with thinner walls and shorter body, so they dissipate heat better and faster to the engine head. The plugs with hot thermal range C (Calda), have a body with thicker walls and longer body, so they retain heat and dissipate heat slower to the engine head. The number of threads is the same on both types of plugs.
How to select the proper plug:
•When the ambient temperature is high, we have to use a plug with thicker wire.
•With higher compression, we have to use a plug with thicker wire.
•Humidity determines if we use a Cold (F) thermal range, or Hot (C) thermal range.
•With high humidity percentage we should use a Hot (C) thermal range plug.
•If we have high temperature and high humidity, we should use a plug with thick wire and a Hot(C) thermal range.
So with up to 20% Nitro you are OK with #5 or 6 plugs, but from 25 to 30% nitro is best you go with #7 or even #8.
Now since you have such a high temp high humidity environment, you should go with C (hot) thermal range type of plug. C7TGC or C8TGC plugs.
Hope this helps
AFM
afm is offline   Reply With Quote
Old 03-17-2010, 03:04 PM   #2568
afm
afm's Avatar
RCPANAMA
In my opinion, for 25 - 30% Nitro, and such high humidity, you should add a 0.10 shim.....lets see what Uriah says about it.
AFM
Old 03-17-2010, 03:10 PM   #2569
rcpanama's Avatar
Hope this helps
AFM
Verygoodexplanation, Thanks
RCPANAMA
Old 03-19-2010, 07:01 AM   #2570
Grinder's Avatar
AFM
Yes, you need to add at least .1mm to run 30% nitro. Use the stock .3mm for up to 20%. 20%-25% you can use .4mm total shims, and for 30% you can use .4-.5mm of shims, especially if it is hot, and humid.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-19-2010, 08:08 AM   #2571
rcpanama's Avatar
OK, thanks Grinder
Old 03-19-2010, 11:06 AM   #2572
The plugs that I had that were bad were the C7TGF. The way to tell is that the plug was supposed to black with a gold tip. The bad ones were silver (regular) with a gold tip.
Really? The C7TGF were always (and are still) black with a gold tip. The C7TF (without the "G") had a silver body and mine had also silver tips. However, I had a lot of issues with C7TGF (black with gold tip). Never sucked a wire through the engine, but some were not glowing bright enough (impossible to tune engine) or died after the run (could not start for the next run).
I was thinking that this could also come from using a heat gun to warm up the engine (pointing at the plug), but my buddys use it as well and don´t have issues with the plugs...
fulcrum2 is offline   Reply With Quote
Old 03-19-2010, 12:03 PM   #2573
OLDSKL's Avatar
Glad to see people are still modding motors
OLDSKL is offline   Reply With Quote
Old 03-22-2010, 10:54 AM   #2574
Default Hi Uriah
Urgent message on the store contact.
Thanks in advance
Luís Cortez is offline   Reply With Quote
Old 03-22-2010, 07:59 PM   #2575
Trader Rating: 15 (100%+)
What is a good 1/8th scale pipe to run with the Cordoba or a R9?
THE DOCTOR is offline   Reply With Quote
Old 03-28-2010, 04:52 PM   #2576
Default Hi Uriah - Order no: 1507 update?
Hi Uriah
Can I have an update on my order please, order was placed 2 weeks ago and I have not had any update except "processing".
If there are any issues with supply could you please let me know
Thanks in advance
Jeremy
(Qld, Australia)
Yeah Right! is offline   Reply With Quote
Old 03-29-2010, 05:56 AM   #2577
Grinder's Avatar
Originally Posted by Yeah Right! View Post
Hi Uriah
Thanks in advance
Jeremy
(Qld, Australia)
Hi Jeremy. Sorry for the delay. The engine will be shipping today. I was waiting on the 2652 pipes that I was told would arrive from the importer. They did not. I will have to mail the pipe to you in a couple of more weeks. The US supply of some on road Novarossi engines, and pipes is terrible. I have been waiting over 6 weeks for them. I will probably wait another couple.
Again I am sorry for the delay on the pipes. I waited to ship everything because I was told by the importer the stuff was coming in, that did not happen. Let me know if this is OK.
Old 03-29-2010, 06:00 AM   #2578
Grinder's Avatar
What is the R9? Do you mean the JP R09? For the Cordoba engine I like the Novarossi 2015 pipe best. It gives the best combination of runtime, and power. It is also very linear. The 2052 is also good. It is a little more peaky feeling. The JP engine likes the same pipe.
Old 03-29-2010, 06:00 AM   #2579
Grinder's Avatar
Thanks in advance
Old 03-29-2010, 06:03 AM   #2580
Grinder's Avatar
I will post a picture of the silver plugs with gold tip. They are C7TGF I have a bunch of them I will never use. I think I may send them back to Nova. I do not want to sell them to my customers knowing they are bad.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
SEO by vBSEO 3.5.0
