Old 02-06-2010, 11:18 AM   #2521
wingracer's Avatar
Trader Rating: 22 (100%+)
There is no advantage to an INS box, other than maybe a bit more fuel mileage and less noise. They are required by rules.
They act like about .5mm smaller venturi. Some more than others.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-10-2010, 03:51 PM   #2522
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
Uriah or other RBM3 users,
Please confirm the bearing sizes below are correct for the RBM3:
front - 7mm x 17mm x 5mm
rear - 11.5mm x 21mm x 5mm
THANKS.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 02-11-2010, 05:51 AM   #2523
Grinder's Avatar
THANKS.
Those are the correct sizes.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 02-15-2010, 09:37 AM   #2524
Hey Uriah I was wondering what motor you you would recommend. The mm 35+21, or the mm flash special. Also is the performance of the flash great enough to warrant the price compared to the mm 35+22.
HoboShop is offline   Reply With Quote
Old 02-16-2010, 10:56 AM   #2525
Carlos's Avatar
Mr. Murnan,
I attemped to send you an e-mail thruogh your website but I assume I was unsuccssful.
Anyways my question to you is can you rebuild and modify A .12 ninja motor. It was improperly broken in at my lhs about two seasons ago. now that I'm getting more serious about racing I find that I'm goin to need a backup motor just in case I lose another brand new motor.
thank you for your time,
Carlos Marcano
Carlos Marcano a.k.a Sponge Bob
R.M.I. Racing
Xray NT-1
Spec-R R1
Carlos is offline   Reply With Quote
Old 02-17-2010, 06:06 AM   #2526
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default winternats
Hey Uriah, Missed you at the winternats, see you at the Worlds Peter
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 02-18-2010, 10:59 AM   #2527
Grinder's Avatar
Originally Posted by Carlos View Post
Mr. Murnan,
Carlos Marcano
Hi Carlos. I can no longer get parts for that engine. If you can get the parts to rebuild it, I can do it. I do have the connecting rods, and bearings for the engine here. You will need the Piston Sleeve set.
Old 02-18-2010, 11:05 AM   #2528
Grinder's Avatar
Depends on your pocket book I guess. The Flash Special is nice. Both can make about the same laptimes though. The Flash is the nicer engine. Black case, better carb, rubber under the head button, steel insert backplate. things like that. The Flash gets slightly better fuel mileage.
Old 02-18-2010, 11:20 AM   #2529
Uriah, looking for a motor to use in uk for our new gt class, 200mm, 220mm or 235mm with a motor limit of .15, last year I ran novarossi 12-5sct against .15 with good results, just wondered if your modded 3 port .12 motors would have similar power?
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 02-18-2010, 12:03 PM   #2530
Carlos's Avatar
Mr. Murnan,
I just got your email from your web-shop.
I see what you're sayin and I think I can get the parts for it.
As far as re-building and if possible modding it maybe you can pm some ideas you may have as to what we can do. The motor itself has zero miles on it the issue was that it was improperly broken in and has no pinch what so ever. I hate seeing it sit there collecting dust so I figure if i can get it re-built why not get it modded as well.
Thanks,
Carlos Marcano
R.M.I. Racing
Xray NT-1
Spec-R R1
Old 02-22-2010, 09:20 AM   #2531
Uriah can you compare the performance of the rb m3 and the mm flash . 12. Which one to get? Please chime in.
Also what engine would be faster the Murnan modified sirio cl7r sti or the Murnan modified flash .21
Old 02-23-2010, 07:18 AM   #2532
Grinder's Avatar
Hi. I can actually make a special .12 for that. I make the 3 port into a 5 port engine for that class. The modified 3 port is faster than a stock 5 port engine.
I have one modified Novarossi NS15S5 engine that has more power than the .12's. Novarossi discontinued this engine though, so there are not replacement parts readily available for it.
Old 02-23-2010, 07:21 AM   #2533
Grinder's Avatar
Mr. Murnan,
Thanks,
Carlos Marcano
PM sent.
Old 02-23-2010, 10:01 AM   #2534
Uriah pm sent
Speedmerchant WGT
Old 02-23-2010, 10:36 AM   #2535
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Solara
SEO by vBSEO 3.5.0
