Murnan Modified Motors
#2506
I would also rate the engines in the following order:
1. MM 35+21
2. MM Flash
3. MM Kangaroo
These are all very fast, and reliable engines for on road racing.
#2507
Why bother getting the tuned, if you can get the MM version. I do not think there are any major internal changes. Probably just some different materials for the special. Hopefully a more durable piston material, just what the Flash needs. We will know for sure the changes very soon.
1. MM 35+21
2. MM Flash
3. MM Kangaroo
1. MM 35+21
2. MM Flash
3. MM Kangaroo
wats up dude you get the offroad motors back sorry for the delay give us a call
#2508
RBM3
Hey Uriah,
I just received my RBM3 today,it looks great!Anyways,just wondering,what's the percentage fuel you used to break in the engine?because,we use 16% Tornado here so I just want to know if I need to remove shims in order to use 16%?
And one more thing,what plugs can I use on the M3?are Nova plugs fine?
#2509
Hey, Uriah I have a O.S. 28XZ I would like to have modified but I have never had a engine modified before please PM me and let me know how this process works.
#2510
Hey Uriah,
Yes, use Novarossi plugs. Use the C6TGF, or C7TGF most of the time.
#2511
Hi Uriah you have mail.
#2512
Thanks Uriah!Anyways,you are spot on with the Flash "Special".They did change the piston.Guess I have to start breaking the bank for a MMFlash Special.
#2513
Grinder
Did you ever modified an RB classico 9??
How you compare the stock engine and the modified??
thank you!
thank you!
#2515
Grinder,
I race here in Maryland at Budds Creek. In fact I live about 10 minutes from 301 Raceway and have seen you guys out there but that is not my interest of racing although I like to just watch. We also race in Richmond, Va. and in North Carolina under the IMDRA.com series of RC drag racing. ALL racers show what engines that they use and the most engine used is the Kangaroo, Xenon "R" & ALPHA, 35+21 and some old C5's.
I wasn't asking at all about your internal mods as that would be stupid to even ask. What I was wondering was simply do you have any drag racers using that MMM modded engine and did they provide to you any data on it's performance. I understand the not marking engine blocks and heads as well but I will say that the 2009 IMDRA Champions used RBmods for the Funny Car/Pro-Mod championship using a Kangaroo and Cordoba, Nitrodynamics took the Top Fuel Championship using a Kangaroo and RBmods took the 2.0 index class with a .18 TZ. Litespeed engineering also provided some serious motors that ran track record ET's but car problems kept them out of the winners circle. There were some guys that had some MMM motors and they said that they simply took the engines off their 1/8th scale cars and like you said, they coulda had the mack daddy drag mod and didn't want us/others to know.
We are 132' drag racers ONLY and use 50-60% nitro on 5-8% oil range. I can care less about fuel milage as it just needs to go from A to B as quick as it can. The record for my Pro-Mod class is 1.604 seconds @84 MPH from a stand still to 132'. THAT is flying and we ALL are trying to be the first to go 1.5's. Basically I am interested in a MMM engine but wanted feedback as well.
Hoboshop, I wouldn't bet anything until it has proven itself. I cannot tell you how many times we have heard such promises/bets that never hold true. It aint all in the motor that makes a great pass, you know that.
Here's my Pro-Mod that uses dual turbo plugs.....one hot and one cold.
#2516
Yes, it is a good engine. After modification the engine has a lot more top end, and still very crisp bottom end. Very good for the $. It does not have the power of the newer high end on road engines though.
#2517
#2518
#2519
#2520
