Old 12-15-2009, 11:39 AM   #2431
lil-bump's Avatar
Trader Rating: 82 (100%+)
Originally Posted by ugglasdav View Post
hey guys, i have only been driving on road 1/10 for a year now and with every race i did it has been always the engine that has givin me proplems. there is a guy in my club with a murnan 353 and i can drive better then him its just the engine that has been letting me down. i hope to get a murnan for next years season. do you think its the right choice or should i stay stock for a while longer
I would stay with a stock engine. A modified engine in going to be a little more sensitive to tuning changes. Get a nice stock engine. Remember slower is faster. learn how to drive and tune slower engine first.
pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 12-15-2009, 01:54 PM   #2432
Send a message via AIM to Bobby Flack
I'd say if you are getting beat on the straight then the only answer is a Murnan RB. There are stupid fast yet still very very easy to tune. You really can't go wrong with one of these motors!
Bobby Flack is offline   Reply With Quote
Old 12-16-2009, 01:39 PM   #2433
ugglasdav's Avatar
hey guys, dont want to be rude or anything but i cant seem to figure out how if u mod an engine to have more power and torque but yet be more fuel econmic
ugglasdav is offline   Reply With Quote
Old 12-16-2009, 02:20 PM   #2434
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Thats not 100% true. All my engines are modded, some are modded by Murnan and they make the same runtime as the rest of the guys.
Some modifications just improve efficiency. If they improve efficiency it means it is getting more power for less consumption!
Riketsu is offline   Reply With Quote
Old 12-16-2009, 05:07 PM   #2435
GMartinez's Avatar
Trader Rating: 85 (100%+)
Bobby Congrats & the P.R. Cup & also tho the Murnan Team
See ya @ the Winternats if your coming down
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 12-16-2009, 06:44 PM   #2436
lil-bump's Avatar
Also with better spool up time. You can grab less throttle; and still get from corner to corner faster.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 12-23-2009, 04:46 AM   #2437
Grinder's Avatar
Pass you soon...
That is correct, with the power increase it takes less throttle to go the same distance. That is one way runtime is better.
Another thing that helps runtime without power loss is the way my modified engines burn the fuel. More of the fuel is being burned and not wasted. Mostly due to the change in the shape of the heads, cranks, weights, and a few secrets...
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 12-23-2009, 01:31 PM   #2438
blis's Avatar
Default Less throttle...
Perhaps there's something to be said about the racer in this matter. A good racing buddy of mine is a modified RB runner, the engine is remarkable, having said this..
As too is his attention to detail on all other aspects of his car, it's not the average "Joe" that would invest in an modified engine of this calibre so free roll of a chassis and rotating mass and inertia comes into play. Attention to bearings, altitude above sea level, car setup, clutch slip, tyre slip all equate to power to ground and overall fuel efficiency.
He gave me an "old" one made from old spare parts, after replacing rear bearing and O-rings the old Murnan RB still rocks for it's age and all I can say is ... they are AWESOME ENGINES!!!
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 12-24-2009, 11:50 AM   #2439
musti72's Avatar
Hi Uriah,
Can you modify a RB T9 Stock version and make it exactly same like an M3, except the new cooling head?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 12-28-2009, 08:25 PM   #2440
has anyone here tried the moded 09 Kangaroo?need some reviews coz keen on ordering one
tq23 is offline   Reply With Quote
Old 12-29-2009, 03:06 PM   #2441
am
Hi.
I am an offroad driver and have used the Nova +4 this seasson. I was wonderring how your engine is to drive compared to a stock +4 engine? Is it the same smooth engine with higher rpm? Are the fuel consumption the same on the modified engine? etc...
Thank you so much for your help and time
am is offline   Reply With Quote
Old 01-16-2010, 03:31 AM   #2442
Grinder's Avatar
Old 01-16-2010, 03:32 AM   #2443
Grinder's Avatar
Originally Posted by musti72 View Post
Hi Uriah,
No. It will be pretty close though.
Old 01-16-2010, 03:44 AM   #2444
Grinder's Avatar
The engine has tons of torque, and good top speed. The engine will run with the best of engines. The Kangaroo is a perfect for those small to medium size tracks. The engine has more bottom end, and slightly less top end than engines like the mod 35+21, Flash, C9.
I hope this helps.
Old 01-16-2010, 03:58 AM   #2445
Grinder's Avatar
Originally Posted by am View Post
Hi.
Hi. The modified +4 feels more aggressive out of the corners, with a lot more top speed than stock. The modified +4 gets similar runtime as the stock engine, with more power. With my modified +4 you can run a smaller ventury, and get the same power as the stock one with much better runtimes. Or you can use the same ventury, and roast your tires off.
I recommend the 5.4mm ventury from a .12 engine to get the most runtime. Most of my off road team drivers are using less nitro, smaller venturies, and still have plenty of power for most off road tracks. For Truggy I use a 6, or 7mm insert. You can also use the 5.4mm in truggy. Talk about extreme runtimes!
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
