Old 09-19-2009, 07:22 AM   #2341
Grinder's Avatar
Originally Posted by wingracer View Post
Interesting that while the Flash has a bit more peak power, it looks like the 35+21 has a LOT more area under the curve. Especially under 35k.
Yep, the good ol 35+21 is still one of my favorites. The Flash has a smoother powerband. Some people like that. I must say when geared correctly they can make about the same laptimes.
The Flash is slightly better on fuel consumption though
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 09-19-2009, 10:14 AM   #2342
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
wanted to say thank you from homestead for the new power from thr RB M3........all I can Say is WOW!
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 09-19-2009, 10:54 PM   #2343
Originally Posted by Grinder View Post
The way to tell is to look at the timing in the crankshaft. There will be modification to the crankshaft timing intake window on the modified version. The sleeve is also not modified on the tuned, only on the modified version. Look for the teardrop cuts on the transfer ports on the modified version. The tuned has a stock looking sleeve.
Thanks for a quick reply. I opened the motor today and found out that it's the modified version. a closer look revealed matched piston and sleeve and crankshaft and head button as they have this matching #s inscribed on them. mines has "4" inscribed on all the parts. really impress with all the works that have been done to the motor. btw, this is my 3rd murnan modified engine from you guys. thanks alot.
jun_808 is offline   Reply With Quote
Old 09-20-2009, 05:25 PM   #2344
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
Raced my new RBM3 over the weekend. So far, this motor is excellent, typically reliability of a Murnan (and RB) motor!
Only have about 1.5 litres through it, it broke it nicely, raced at Moorebank (large, open 1/8th type track) where run time is usually an issue. Motor ran nice and cool and was making about 5:20min on a tank (I have owned MM 353s, Capricorns, Sirios etc which struggled to make run time with my driving, so this is great considering the motor is not yet fully broken in). Ran it with a 2652 pipe.
Motor is still tight (about 80-90% broken in), but so far I would easily compare it with my MM353, so its full potential should show at the next couple of race days.
Michael.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 09-21-2009, 05:29 AM   #2345
I would like to thank Uriah for the awesome horsepower and runtime from the RBM3. I was able to take the win at the 1/10 scale Mid Atlantic Touring Car Championship in Richmond, Va this past weekend. I ran the M3 combined with the 2601 pipe and Nova medium header and got 5:45 runtime with the engine coming off the track after the 30 minute main at 265 degrees. Thanks again for the incredible power, run time, and reliability. GO MURNAN!
Charlie Wilson
THANKS to VISA, MC, TWISTER TIRES, and my WIFE
MY RIDE - MTX4R, MURNAN RBM3, RB R3, NOVA 2601 & 2630, TWISTER TIRES, MAXYS FUEL
MY OTHER RIDE - CRC GEN XL, TEKIN RS PRO, REDLINE 10.5, THUNDER POWER 1-CELL, AND AGAIN TWISTER TIRES
cdub1 is offline   Reply With Quote
Old 09-24-2009, 02:09 PM   #2346
@Grinder: Any thoughts?
Originally Posted by fulcrum2 View Post
@Uriah,
how would you compare a Nova S21WCS09 against a 35+21? The little Nova carries an attractive price tag
2nd question: Would you personally rather pick a MM Cordoba or a MM 35+21? The price is the same and after your mods power output should be the same as well. Should I choose just by cooling head color or are their any other important differences?
Many thanks and best regards,
Stefan
fulcrum2 is offline   Reply With Quote
Old 09-24-2009, 02:28 PM   #2347
wingracer's Avatar
If I'm not mistaken, doesn't the Cordoba have the smaller crank pin?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-24-2009, 03:59 PM   #2348
Grenade10's Avatar
Trader Rating: 37 (100%+)
I've been very happy with my 35+21 MM engine in my MRX4x. Ran very strong at Nationals it was just a little "Thirsty"
Any thoughts on how to get the millage up?
I'm running Byron 25% with an additional shim, Novarossi 2015 pipe, med concical header. I did find being less agressive on the throtle helped, and I understand that the tank is a little small in the Mugen.
Thanks for the help.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 09-24-2009, 11:35 PM   #2349
No small crank pin on the Cordoba - Only the 359 has the small one (which gave me no issues over 5 gallons btw.)
Old 09-25-2009, 07:52 AM   #2350
rjr
Lean it! You were blowing way too much smoke.
rjr is offline   Reply With Quote
Old 09-25-2009, 08:35 AM   #2351
Grenade10's Avatar
OK
Old 09-25-2009, 04:04 PM   #2352
RCAKid's Avatar
I would like to thank Uriah Murnan for providing me with the incredible power and reliability of the Rb M3 wich allowed me to TQ the first round of the Florida State series infortunatly trouble struck early in the main and i tangled with a lapped driver causing me to chunk a tire however i did end up finishing the race in fourth. with the TQ point i am tied for third in the points thank you Uriah.
Tommy D
sponsors
Murnan Modified Motors- RbM3
Rc America- Nt1
Mom & Dad
RCAKid is offline   Reply With Quote
Old 09-28-2009, 07:47 AM   #2353
Big Jeff BBQ's Avatar
Tommy D
RCA was a bad name T.V.! hehehehehehe!
How is everything tommy.
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 09-29-2009, 01:16 AM   #2354
Gentlemen,
most of the fast guys in our series run the Max XL9TQ. I would rather like to run a Murnan Nova - So which one is on the same level? Has anyone had a change to compare a Murnan vs. that Max engine?
Thanks a lot, Stefan
Old 09-29-2009, 05:37 AM   #2355
RCAKid's Avatar
Not bad big jeff how are you. I hope your still going to the open.
sponsors
Rc America- Nt1
Mom & Dad
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
