Old 05-21-2009, 09:12 PM   #2221
Originally Posted by ToysRUsKid View Post
I ordered a replacement rod for my R3RC (Nova 07601) and I got a Max Power 07601, didn't think anything of it. I put the rod in, put piston and sleeve back together, and it doesn't turn over. The rod gets to the bottom of the case, and gets stuck. I took it back out, and measured the width. The Nova rod is 4.18mm and the new Max rod is 4.21mm. Now the person I ordered it from is telling me they are the same. I'm sure they are supposed to be, but i'm looking at this one and tried it and it's obviously not the same. Anybody know why this would be so off?
I replaced the rod after break in with a Nova 07601 and it worked fine. this max rod is not working.
7601 is 7601, meaning only Novarossi makes it and package under different brands, you must be doing something wrong.
ich weiß
hello is offline   Reply With Quote
Old 05-21-2009, 09:53 PM   #2222
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I did something wrong, because now it's fine. Thanks to Sam from Kamikaze hobbies for emailing me back and forth until it was right.
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 05-22-2009, 03:54 AM   #2223
Grinder's Avatar
What about glow plugs? how do you know when to use a medium instead of a cold?
I use the hotter plug if the engine seems to be loading up, and flaming when you come into the pits. Or it seems hard to clear out. You can tune the engine to use any plug. The colder plug will allow you to tune for better runtime.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 05-22-2009, 03:56 AM   #2224
grub's Avatar
make shore your conrods oil hole is face the rear bearing and the piston is not in back to frount as it will hit the crank on the down stroke
ok see you fixed it did not read the last page of posts
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 05-22-2009, 04:06 AM   #2225
Grinder's Avatar
Can you take a picture of the two rods? Does the Max rod hit the bottom of the case, or the sides of the groove in the case?
Old 05-22-2009, 06:11 AM   #2226
ToysRUsKid's Avatar
That's what it "was" doing the first two times I tried it. I went back later and it's a perfect fit, not hitting. Must have been sleepy or something.
Old 05-22-2009, 06:12 AM   #2227
ToysRUsKid's Avatar
Cool, thanks for the info. See you at the cap in a few weeks.
Old 05-22-2009, 12:35 PM   #2228
spurgear's Avatar
Send a message via MSN to spurgear
Uriah i sent u an email and also tried calling u a couple times over the past week. How can i reach u?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 05-22-2009, 12:45 PM   #2229
LowBoost's Avatar
Trader Rating: 63 (100%+)
Same here... called a few times.. nothing.
LowBoost is offline   Reply With Quote
Old 05-25-2009, 02:49 AM   #2230
Wynnum_Racer's Avatar
A murnan novarossi 12 SCT grunting along.
http://www.youtube.com/watch?v=j1LL0xO0wT0
http://www.youtube.com/watch?v=canY93sF15I
http://www.youtube.com/watch?v=NmxE9udKKdA
Everyone watch my movies on youtube
Wynnum_Racer is offline   Reply With Quote
Old 05-25-2009, 05:23 AM   #2231
KyoshokiddT.D's Avatar
uriah has prob been buisy. leave a message and i am sure he will return your calls
KyoshokiddT.D is offline   Reply With Quote
Old 05-25-2009, 09:17 AM   #2232
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Don't cry. Something new is coming soon.
What is it???
Give us a clue or a sneak peak!
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 05-25-2009, 02:48 PM   #2233
Thumbs up
3rd place at Turkish Nationals with my m353r
Break-in was not easy, the engine was very tight. I simply recommend getting your engine with murnan break-in option.
The engine has a very very smooth torque curve. Bottom end, middle and top end are almost same. It simply pulls at your command. I use a novarossi medium length 2630 pipe with mugen exhaust pressure cooler ( the one that look likes a big empty fuel filter ). Fuel consumption is high. Getting 5minutes at nationals was tricky for me.
Tuning m353r is easy. I must say I'm very very surprised. It has a nice sweet-spot for high-end needle. Low speed needle needs spending some time for fuel millage. During 1 hour a-main and qualifiers I did not have any carburation problems or unexpected flame-outs.
A problem-free, fast, easy to tune engine. Most importantly it is an engine you can trust.
Thanks grinder
1nsane is offline   Reply With Quote
Old 05-27-2009, 12:38 PM   #2234
ToysRUsKid's Avatar
Anyone know which Nova shims will fit the RB MatrixRW .12 motor? I've been told it's a Sirio based motor, but I can't find Sirio shims anyplace and the shims that fit my R3RC seem to have an inside diameter too small for the Matrix.
Old 05-28-2009, 04:54 AM   #2235
Default RBM3
The new RBM3 motor sounds great. plus I have been very happy with my MM RBR3. But is the RBM3 the hottest motor? Is it better than, for example, the MM Novarossi 353 2009, and the M353R modified?
Is there a new MM Novarossi .12 motor coming out soon?
I want the best one, which do I get?
Thanks.
Jongo is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
