Old 05-13-2009, 05:15 PM   #2206
grub's Avatar
Originally Posted by Grinder View Post
Don't cry. Something new is coming soon.
The full ceramic has front, and rear ceramic bearings.
any dates and what is it a nova sirio jp ????????
come on uriah the suspence is killing me
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 05-18-2009, 10:45 AM   #2207
ToysRUsKid's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to ToysRUsKid
Anyone know which Novarossi plug fits an RB R3RC?
Also, I'm running 25% fuel, which plug should I be using?
Also, how often should I change the conrod? I know I got the conrod from Murnan but it was a Nova rod and I don't remember which one.
Dorian Tisdale - Professional RC Driver Wannabe
RC America \ DeSoto Racing \ XRay \ Novarossi
www.tsrcar.com \ Red Mosquito raceway \ www.racersoftoledo.com \ www.midwestseries.com
ToysRUsKid is offline   Reply With Quote
Old 05-18-2009, 05:09 PM   #2208
You need the Nova 7601 conrod. Only replace it if it has slop in it, pull the cover off and turn the crank so the piston goes to TDC and then turn the crank back and forth to see if there is any play between the rod and crank pin.
THANKS to VISA, MC, TWISTER TIRES, and my WIFE
MY RIDE - MTX4R, MURNAN RBM3, RB R3, NOVA 2601 & 2630, TWISTER TIRES, MAXYS FUEL
MY OTHER RIDE - CRC GEN XL, TEKIN RS PRO, REDLINE 10.5, THUNDER POWER 1-CELL, AND AGAIN TWISTER TIRES
cdub1 is offline   Reply With Quote
Old 05-18-2009, 05:42 PM   #2209
rb says to replace the rod every gallon of fuel i replaced mine twice already
infernoman2008 is offline   Reply With Quote
Old 05-18-2009, 05:50 PM   #2210
ToysRUsKid's Avatar
Thanks.
Old 05-18-2009, 06:08 PM   #2211
ToysRUsKid's Avatar
Anything else needs to be replaced when replacing the rod?
Old 05-19-2009, 02:15 AM   #2212
Check the front bearing for air leaks. Block the carby air inlet and exhaust outlet, connect a bit of fuel tube onto the carby fuel inlet. Then get some very soapy water, brush the soapy bubbles on to the motor and blow into the fuel tube. If the front bearing is leaking, put a new one in. At the same time check for air leaks around the carby base, etc.
Also check that both the front and back bearings are spinning freely.
Jongo is offline   Reply With Quote
Old 05-19-2009, 12:06 PM   #2213
I replace the wrist pin just because you have to take it out anyways.
Old 05-19-2009, 12:12 PM   #2214
ToysRUsKid's Avatar
What about glow plugs? how do you know when to use a medium instead of a cold?
Old 05-19-2009, 05:59 PM   #2215
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
almost every high end .21 onroad motor ive owned had a tiny leak thru the front bearing? also as for the rod, change the first one after a gallon, and go from there every gallon sounds like overkill a bit to me, but who knows, i would think after first swap out, i usually go every OTHER gallon...
Trying my hand at electric in off season...TLR Sct 2.0---Trinity D4 10.5---HobbyWing 120 amp Black Edition---Trinity the "Brick"--Panther tires--Savox
TommyBlazin is offline   Reply With Quote
Old 05-21-2009, 06:21 AM   #2216
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
close, but no cigar
do you like the orange colour?
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 05-21-2009, 10:33 AM   #2217
musti72's Avatar
Let me guess, is that a Murnan RB T9 coming?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 05-21-2009, 10:56 AM   #2218
Nitro-Racer*'s Avatar
hahaha i love orange with murnan you can even change your favourite colour well anyway i hope the orange stands for rb.....
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 05-21-2009, 04:22 PM   #2219
grub's Avatar
i was expecting a murnan .12 flash or the rb t9
to be next of the producton line
yes ilove orange
Old 05-21-2009, 09:53 PM   #2220
ToysRUsKid's Avatar
I ordered a replacement rod for my R3RC (Nova 07601) and I got a Max Power 07601, didn't think anything of it. I put the rod in, put piston and sleeve back together, and it doesn't turn over. The rod gets to the bottom of the case, and gets stuck. I took it back out, and measured the width. The Nova rod is 4.18mm and the new Max rod is 4.21mm. Now the person I ordered it from is telling me they are the same. I'm sure they are supposed to be, but i'm looking at this one and tried it and it's obviously not the same. Anybody know why this would be so off?
I replaced the rod after break in with a Nova 07601 and it worked fine. this max rod is not working.
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 01:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 03:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 09:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 09:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-20-2004 12:01 AM
SEO by vBSEO 3.5.0
