Murnan Modified Motors
#2116
Hi. I recommend Rocket Science fuel. I have also tried some other good fuels like J-Tech fuel. If these are not readily available the Byrons Gen 2 is a good alternative.
I have a couple of break in methods that we use with success listed on my website. http://murnanmodified.com/breakin.php
I am out of the 2630 for another week or so.
I do have the medium headers in stock.
#2118
Grinder, you have pm and lots of emails
#2119
Uriah, another PM thank you.
#2120
Team Murnan had 5 out of 10 engines in the sedan A main at the Florida State Race at Kissimmee Raceway. Congratulations guys. A special congratulations to Chris Lefebvre for winning the A main sedan with Murnan power.
1 3 100 30:09.73 Chris Lefebvre Murnan +12-3SCT
2 1 99 30:01.27 DJ Apolaro
3 4 99 30:04.17 Andrew Duperrouzel
4 2 99 30:15.20 Uriah Murnan Murnan M353R Modified
5 0 95 30:10.03 James Burrows
6 8 93 30:05.75 Tommy DeSantis Murnan M353R Modified
7 6 92 30:15.87 Eduardo Cabal
8 9 82 30:12.79 Marcus Moten Murnan M353R Tuned
9 5 29 9:28.74 Anthony Andrews Murnan M353R Modified
10 7 18 12:29.94 Peter Breton
Way to go guys!
Way to go guys!
I think there were 3 or 4 Murnan Modified in the B Main !
How Quick we forget the B main !
Later
Jeff Epperson
Blowin Smoke BBQ
#2121
Suspended
trick pony
so are you sayin your engines are cheaper whith the giddy up? bonehead
#2123
I have A question I just bought a mm nova rossi +12-3sct i am wondering what hearder to choose. and what are the difference between long, med, short headers. I already have a new nova 2630 pipe. thanks
#2124
#2125
The short header will make it's peak power around 45,000 rpm. The medium around 42,000, and the long at around 39,000.
I use the short most of the time. I will use the medium if I feel the engine needs to spool up quicker. The longer the header will make the engine get to it's peak power quicker than the shorter headers, but with less peak HP, and Torque. I usually reserve the long header for the smallest of tracks.
#2126
thanks for the info it helped a lot
#2130
I have seen this occur in one brand new RBR3 that I was taking apart. I took the backplate off, and there were pieces of piston inside the engine. I am still waiting on a replacement for that after one year.
Those are my only guesses.
