Old 03-09-2009, 06:51 PM   #2101
LefebvreC's Avatar
i can thank uriah for the great motor i had this weekend. It had awesome power out of the corner and down the back stretch. I would also like to thank everyone on congradulating me on the win.
Team Serpent America
Maxy's fuel and modified engines
RC paintin Pete
LefebvreC is offline   Reply With Quote
Old 03-10-2009, 12:50 AM   #2102
prg
wonder if anyone can help. i have a murman mod 353, seams to run well But when i get refuelled it coffs and splutters and nearly flames out for a couple of seconds then its fine again. Any advice would be apprieciated
prg is offline   Reply With Quote
Old 03-10-2009, 06:20 AM   #2103
quietstorm76's Avatar
Nice win Chris, you earned all of that one.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 03-10-2009, 06:57 AM   #2104
Grinder's Avatar
If the engine is blowing lots of smoke when that happens, you need to lean the engine. If it revs really high with no smoke, you should richen the engine.
Thanks, Uriah
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-10-2009, 07:30 AM   #2105
Grinder's Avatar
Default Congratulations Team Murnan Drivers
Team Murnan had 5 out of 10 engines in the sedan A main at the Florida State Race at Kissimmee Raceway. Congratulations guys. A special congratulations to Chris Lefebvre for winning the A main sedan with Murnan power.
1 3 100 30:09.73 Chris Lefebvre Murnan +12-3SCT
2 1 99 30:01.27 DJ Apolaro
3 4 99 30:04.17 Andrew Duperrouzel
4 2 99 30:15.20 Uriah Murnan Murnan M353R Modified
5 0 95 30:10.03 James Burrows
6 8 93 30:05.75 Tommy DeSantis Murnan M353R Modified
7 6 92 30:15.87 Eduardo Cabal
8 9 82 30:12.79 Marcus Moten Murnan M353R Tuned
9 5 29 9:28.74 Anthony Andrews Murnan M353R Modified
10 7 18 12:29.94 Peter Breton
Way to go guys!
Old 03-10-2009, 08:54 AM   #2106
wmay11's Avatar
I had my Murnan 35 plus 21 running at 282 the weekend and it seemed ok, what can you push these motors to run? Ran a #6 plug and .7mm head clearence. I would like to run it hotter and redce the cearence to .6 maybe with an 8 plug. Is 330 to hot?
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 03-10-2009, 03:46 PM   #2107
c1 racin's Avatar
Send a message via ICQ to c1 racin Send a message via AIM to c1 racin Send a message via Yahoo to c1 racin
Grinder,
Picked mine up from NeXus Racing this weekend .... couple of question
1) What Brand fuel do you recommend?
2) What break-in method?
3) Do you have the Novarossi 2630 in stock?
4) Do you have the medium header in stock?
thanks for all your time ...
NeXusRacing.com
MurnanModified.com
MobileRCRacing.com
c1 racin is offline   Reply With Quote
Old 03-11-2009, 06:44 PM   #2108
Default mt12
Hey grinder. Ive got a mugen mt 12, it has been broken in almost. About 5 tanks through it before my racing season ended. It was properly stored, and after inspection is free of any corrosion and still has enough pinch to keep me from turning the crankshaft past tdc.
My question for you is, I read here that you will only work on new or nearly new engines. Does my mt12 fall into this category. Furthermore, would you do work on a motor that is no longer in production.
Thanks in advance.
Jason
thewood1987 is offline   Reply With Quote
Old 03-12-2009, 06:46 AM   #2109
Grinder's Avatar
Hi. You can push the engines to higher temps than 280. The most important thing to check is the combustion chamber. As long as there is still some oil you will be OK. Make sure after the run, without letting the engine run out of fuel the glowplug does not look dry. A dry glowplug means you are too lean.
You should only run the Novarossi C7TGF in that engine. You will see much better performance, and cooler temps than the 6 you are running now.
Leave the clearance where it was stock.
Old 03-12-2009, 06:49 AM   #2110
Grinder's Avatar
Originally Posted by c1 racin View Post
Grinder,
Hi. I recommend Rocket Science fuel. I have also tried some other good fuels like J-Tech fuel. If these are not readily available the Byrons Gen 2 is a good alternative.
I have a couple of break in methods that we use with success listed on my website. http://murnanmodified.com/breakin.php
I am out of the 2630 for another week or so.
I do have the medium headers in stock.
Old 03-12-2009, 06:50 AM   #2111
Grinder's Avatar
Thanks in advance.
Jason
Hi. That engine should fall into that category. Send it in, and I will let you know. It has been a few years since I modified one of those. Should be fun.
Old 03-12-2009, 08:12 AM   #2112
wmay11's Avatar
Thank you Grinder for the info, I found your motor very easy to tune and predictable which was a pleasure when you running a Nat. I will leave the clearence at .7 and change the plug. The motor seemed to like a richer bottom with the 2052 pipe. What temp did you find best for these motors? I am running Klotz oils 6% Techniplate and 5% Benol degumbed castor.
All the best!!!!
Old 03-17-2009, 01:31 PM   #2113
Timmo's Avatar
Trader Rating: 15 (100%+)
Does anyone have any experience with the Murnan Modified
Ninja MR21 R01A on-road engine?What are the mods based on.
Is it for power,speed,or fuel economy??Any thoughts or comments are welcomed.
If Murnan himself would explain it,I would be honored..
Timmo is offline   Reply With Quote
Old 03-17-2009, 07:02 PM   #2114
wizby's Avatar
I dont know about that ninja but in general he improves all of those. His nova's ive run have more bottom and top and fuel economy.
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 03-17-2009, 07:58 PM   #2115
TrickPonYracing's Avatar
Two out of the top three qualifiers where murnan mod motor and they finished in the same order in the money at the ss raceway Tampa fl. Thanks for super fast and consistent power
Nitro Sedan - A Main
1. Chris Lefebvre $$$ murnan mod 12 +3ct
2. James Burrows $$
3. Gary Tuttle $ murnan mod m353r
4. Gary Soltys
5. Dru Garcia
6. Rich West
7. Manny Cosmo
8. Ronnie Setser
9. Jack Anderson
10. Ron Taylor
www.TrickPonYracing.Com
FORGASS President 2006/2007.2007/2008. 2008/2009
V/P Charlotte R/C Raceway
Team Anchor for .. ReD CuP RacinG ..
Team Driver for TORO Fuel
torofuel@aol.com
TrickPonYracing is offline   Reply With Quote
MURNAN MODIFIED PLUS 21-7BT tmperformance1 R/C Items: For Sale/Trade 4 02-11-2008 12:00 PM
MRX-4R,murnan modified 35+21 ltrdude R/C Items: For Sale/Trade 19 12-11-2007 02:29 AM
Ninja TA01 Murnan Modified,OS TZ Modified GMartinez R/C Items: For Sale/Trade 31 08-20-2007 08:40 PM
Murnan Modified horizon644 Nitro On-Road 1 02-06-2007 08:32 PM
Murnan Modified Motors AlanLim Onroad Nitro Engine Zone 1 04-19-2004 11:01 PM
